![]() | Home > Maintenance & Mods (L322) > Whel balance issues, or is it?? |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Sticky brake caliper would give that sort of vibration at speed. Current Fleet:-
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Hi
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
What makes you think wheel balance? When my tires are out it becomes noticeable in the front end. It also makes every other slightly worn joint resonant. Rears need to be way out to notice. My tire guys say that large tires are a pain to get balanced perfectly. |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
Thanks Strider, the propshafts have CV joints on both ends, with a single UJ by the centre bearing on the rear prop. Everything "feels" fine, but to test the centre bearing I need to remove the entire exhaust again, so I will probably tackle that next weekend time allowing. On Saturday past the tyre dealer fitted new set of michelins all around, and they are much better, but still not perfect, this Monday / Tuesday coming they will fit set of new Pirelli's as a 4th comparison.. I am picking up a tremendous amount of negativity on Conti's on local forums, many many out of round issues.. During the process of fitting the Michelins I had the opportunity to place the fattie on the wheel alignment bay, which allowed me to stand in the pit under the vehicle where I was then able to use a crowbar against each suspension bush to test for excessive play, and they all seemed quite fine, not weird play or knocking at all. By the way we live at approx 1900 m altitude, we do not have humidity issues and while we have summer rainfall, there is no rust on my fattie, winters are dry and no salt used on the roads so I guess we are quite lucky in this regard, our cars last a long long time.. I checked the front halfshafts for play and they were fine, nothing out of the ordinary, the rear is a different story though as I have a very small amount of play on the right rear inner CV, in essence standing under the car pushing upwards on the inner rear right CV allows a small rocking motion, not sure if the bearing in the diff is setup poorly allowing for play. I must stress that the movement is small, probably a couple of tenths at the most, but its there while there is none on the left rear halfshaft, just possibly this could cause the imbalance but somehow I do not think that is it.. By the way, with the fatty in the air on all 4 corners, we ran her in lowrange to keep wheel revolutions low, and checked each wheel for hub runout, just in case, and there was none, all 4 halfshafts running nice and true, nothing bent.. Front bearings were replaced about 5 weeks ago, I used original LR supplied bearings, forget the brand name, but same make as the originals which came off. I have not replaced rear bearings, but there is no play or noise from the back wheels.. Last edited by marcochezzi on 4th Mar 2018 9:38pm. Edited 1 time in total |
Thanks Doclees, simply put the frequency of vibration or "bump" feels in line with tyre rotational speed, I know that sounds like a bunch of croc but propshaft misbalance vibration is generally higher frequency, I have battled for years in that regard on my Jeep CJ7. Then there's a sweet "spot" where obviously the harmonic is at its highest because the "thump" or bump is quite significant, I do not know if a small mis-balance on a driveshaft could produce such force & feel. Maybe its rear shocks as well, which I should replace, but with the mystery snake oil in these electrically "adaptive" shocks its not exactly a cheap diagnostic as its JLR dealer only goods in this neck of the woods.. |
Never thought of that, I should take a look at that, thank you for the suggestion.. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
Have the tie-rod ball-joints and the rack been checked? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Why are you running that size of tyre? I believe worldwide they should be running 255 50 20... Could this be a small issue???
Nope, certainly I cannot feel any play in the steering, and when I visually check the tierods there is no abnormal play or movement due to worn joints. would steering rack wear not result in a steering wheel shimmy?? |
Unnecessary quote removed
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 had similar and it was offside rear calliper sticking so replaced them both ![]() |
The rear callipers sticking have been an ongoing issue for years sir |
Thanks Craig, honestly did not know that, will get some prices today and probably order and be done with it, another tick of the box..!!.. |
Thank you Sandyt!! |
