![]() | Home > Technical (L322) > Special features won’t enable |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
I expect that there is a fault with one of the pre-requisite systems, such as a brake, steering angle sensor or suspension system error. If you don't see any messages on start-up then the fault codes will need to be read.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
on the 4.4 (2011) it'd be the adaptive damper cables which are quite an easy fix.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
+1 for checking the adaptive damper cables, though this tends to throw the adaptive dynamics fault message too, could be the yellow triangle message....
Bennyis01 Member Since: 02 Mar 2018 Location: Birmingham Posts: 15 ![]() ![]() ![]() |
Thanks for your help peeps, will check cables. I keep getting adaptive dynamics fault but keeps coming and going but changed cables in summer . I didn't realise that this would affect special features mode |
Optional on MY10, standard on MY11/12. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Have you disconnected the battery recently?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
he says he has ... ... - .- -.
Right guys thanks for all your help I managed to get out side and check cables for suspension struts and as diagnosed one of the legs had a break in it
Glad it was the easy fix.
