Home > Technical (L322) > Special features won’t enable |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2314 |
I expect that there is a fault with one of the pre-requisite systems, such as a brake, steering angle sensor or suspension system error. If you don't see any messages on start-up then the fault codes will need to be read.
3rd Mar 2018 12:38pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
on the 4.4 (2011) it'd be the adaptive damper cables which are quite an easy fix.
3rd Mar 2018 12:50pm |
+1 for checking the adaptive damper cables, though this tends to throw the adaptive dynamics fault message too, could be the yellow triangle message....
3rd Mar 2018 1:29pm |
Bennyis01 Member Since: 02 Mar 2018 Location: Birmingham Posts: 15 |
Thanks for your help peeps, will check cables. I keep getting adaptive dynamics fault but keeps coming and going but changed cables in summer . I didn't realise that this would affect special features mode |
3rd Mar 2018 2:30pm |
Optional on MY10, standard on MY11/12. |
3rd Mar 2018 8:55pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Have you disconnected the battery recently?
3rd Mar 2018 9:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
he says he has ... ... - .- -.
3rd Mar 2018 9:37pm |
Right guys thanks for all your help I managed to get out side and check cables for suspension struts and as diagnosed one of the legs had a break in it
4th Mar 2018 4:51pm |
Glad it was the easy fix.
4th Mar 2018 8:12pm |
