Home > Maintenance & Mods (L322) > Brake Pads........easy to replace....??
Rob99
Just had the brake pad worn warning come up (not bad after 34,000 miles Shocked )
Before I start taking off wheels and checking, how easy are the pads to replace and what issues do I need to look out for?
I'm going to use genuine parts but don't want to pay the labour rate for a garage when I'm pretty handy mechanically myself.
Rob 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #472413 13th Mar 2018 2:35pm
Baltic Blue
Getting the retaining pins out can be a bit of a pain if they are corroded.
Some members report that they have had to cut them and then fit new pins.
Also some debate about using copper slip grease on alloy calipers, but most do .
Post #472422 13th Mar 2018 3:32pm
Captain Black
England 2018 Range Rover Vogue TDV6 Corris Grey
That looks like interesting information Baltic Blue, would you mind me asking where you downloaded it from if its also available for L405 model
Post #472424 13th Mar 2018 4:04pm
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
Couple of things:
1) that middle bolt isn't mentioned in the Wiki but I presume it just unscrews?
2) has anyone used EBC pads for their 4.4 TDV8 car? I used to run a BMW 335i and found Red Stuff EBC pads very good, and low dust too. Anyone used Red Stuff, or Green Stuff for one of these cars?
Post #472431 13th Mar 2018 4:36pm
mpirie
From memory, the centre bolt is actually a pin used to keep tension on the anti-rattle spring, so no unscrewing to be done.
Can't comment on the EBC pads i'm afraid.
Mike
Post #472435 13th Mar 2018 4:46pm
nino_nino
it is 1 and 3 pins in the picture that tend to get stuck. use some release fluid ( I use 50/50 mix of ATF and acetone) to aid in removal.
cob, I have used EBC discs and yelo pads and went back to brembo discs and Jurid pads. EBC discs warped and pads were noisy.
Nino,
Post #472449 13th Mar 2018 5:59pm
counter of beans
Thanks Nino, sounds like good advice Thumbs Up
Post #472461 13th Mar 2018 6:52pm
Rob99
Thanks all, doesn't look any more difficult than others I have done before Thumbs Up
Do the calliper pistons need to be turned as they are pushed in? 2021 D350 Fifty Edition - Carpathian Grey
Post #472497 13th Mar 2018 9:28pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I had a Nissan Sylvia turbo back in the 90s and tried for 5 hours to force the pistons back into the caliper befoee i realised they twisted in !!!!!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #472511 13th Mar 2018 10:18pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Dolph
I did the same thing with my Silvia turbo!! 2007 3.6 TDV8
Post #472771 16th Mar 2018 7:23am
mpirie
No, they just push straight back in.
Mike
Post #472783 16th Mar 2018 9:47am
Baltic Blue
Captain Black,
The picture is a screen grab from the Workshop Manual.
It only covers L322 models, but you could get the L405 Manual by taking out a days subscription to Topix . (Approx £20)
Post #472787 16th Mar 2018 10:08am
