![]() | Home > Maintenance & Mods (L322) > Brake Pads........easy to replace....?? |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Getting the retaining pins out can be a bit of a pain if they are corroded.
Captain Black Member Since: 13 Mar 2018 Location: Cambridgeshire Posts: 30 ![]() ![]() ![]() |
That looks like interesting information Baltic Blue, would you mind me asking where you downloaded it from if its also available for L405 model |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Couple of things:
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
From memory, the centre bolt is actually a pin used to keep tension on the anti-rattle spring, so no unscrewing to be done.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
it is 1 and 3 pins in the picture that tend to get stuck. use some release fluid ( I use 50/50 mix of ATF and acetone) to aid in removal.
Thanks Nino, sounds like good advice |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1481 ![]() ![]() |
Thanks all, doesn't look any more difficult than others I have done before |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I had a Nissan Sylvia turbo back in the 90s and tried for 5 hours to force the pistons back into the caliper befoee i realised they twisted in !!!!!! 2015 4.4 AB
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Dolph
No, they just push straight back in. Mike |
Captain Black,
