![]() | Home > Technical (L322) > Help - Judder under light breaking |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 ![]() ![]() ![]() |
I have had a problem with judder under breaking for about six months now. The disk and pads were new Land Rover and about six months old at the time the judder started. Following a suggestion from another FFRR forum member I Tried scrubbing off the pads with some brisk breaking and initially thought this had worked, but I was kidding myself.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 710 ![]() ![]() ![]() |
You need the discs checking for Disc Thickness Variation (DTV) - which is often a cause of judder.
Thanks for the replies, I haven't looked at the rear brakes at all and they are still the originals at 80K miles. |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I had juddering too that was eventually eliminated by replacing the rear discs and pads having already replaced the fronts along with the lower suspension arms.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
If they are the originals at that mileage then they are due for a change, but I would also check the calipers aren’t binding. |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
I had this too. But I know exactly what caused it on my L322 - a bent brake disk.
