![]() | Home > Technical (L322) > Help - Judder under light breaking |
| Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137
I have had a problem with judder under breaking for about six months now. The disk and pads were new Land Rover and about six months old at the time the judder started. Following a suggestion from another FFRR forum member I Tried scrubbing off the pads with some brisk breaking and initially thought this had worked, but I was kidding myself.
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
You need the discs checking for Disc Thickness Variation (DTV) - which is often a cause of judder.
Thanks for the replies, I haven't looked at the rear brakes at all and they are still the originals at 80K miles. |
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
I had juddering too that was eventually eliminated by replacing the rear discs and pads having already replaced the fronts along with the lower suspension arms.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
If they are the originals at that mileage then they are due for a change, but I would also check the calipers aren’t binding. |
| bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88
I had this too. But I know exactly what caused it on my L322 - a bent brake disk.
| All times are GMT |
