Home > Maintenance & Mods (L322) > Brakes, to grease or not to grease, that is the quesation
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Rob99 said :
[The new genuine pads I've just put on the front (6 pot brembo calipers) had a sticky adhesive layer on the back of each pad too.]
Thanks for that info - Interesting !
Why would they want you to grease a self adhesive pad - lol.
That suggests to me the WM instruction for the 6 pot brembos is an error (not unknown ?) Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #475193 8th Apr 2018 9:32am
maybe all pads havnt got the self adhesive layer... ... - .- -.
Post #475197 8th Apr 2018 9:38am
pld118
I'm confused.
If you're not supposed to follow the guidance manual and you're not supposed to grease the back of the pads where they come into contact with calliper Pistons, then where are you supposed to apply grease or ceramic equiivelant?
Ps... On many occasions when I've greased the rear of pads and piston contacts it has not banished brake squeal.
Confused
Post #475214 8th Apr 2018 3:00pm
Pawl
The only grease of probable benefit is between the pads & the contact areas they slide against on the calliper housing or carrier - depending if Brembo type or sliding housing type (eg RR rears).
However, for newish calipers - before the rust sets in, it's going to make minimal effect, because the pads should slide OK on the anodised aluminium of the calliper housing or plated cast iron of the carrier.
The 2 WMs for 2002 ~05 & 06 ~ 10 make no mention of using any grease on the pads.
I'm not surprised that grease between the pad & the piston made no difference to squeal, it actually makes it easier for the pad to vibrate & therefore make noise. Paul,
Post #475219 8th Apr 2018 4:57pm
Baltic Blue
Is it worth an email to Brembo for their opinion?
Post #475222 8th Apr 2018 5:44pm
pld118
This video is quite good methinks and most of it, I've learned from... 3 million people were interested enough!
Not covering the RR but comprehensive::
https://www.bing.com/videos/search?q=How+t...ORM=VRDGAR
Post #475227 8th Apr 2018 6:46pm
Clabs
I have a new set of Land Rover 6 pot pads to fit to mine when it stops raining. For anyone interested, here is a pic of the back of one of the pads. That stuff with 3m VHB logos is just a protective backing sheet that pulls off to reveal a very thin, and very sticky translucent tape.
 Current Cars:
MY11 5.0 SC Stornoway - sold
MY06 TD6 Zambezi - sold
1997 BMW E36 M3 Evolution Convertible Estoril
Post #475239 8th Apr 2018 8:30pm
I’ve just ordered some new pads so this job is on the cards, I’m pretty sure that last time I just greased the edges of the pad but they did squeal a bit for a few hundred miles till they had bedded in. There is nothing that can't be fixed with a hammer😜😜
Post #475247 8th Apr 2018 9:16pm
Rob99
Did mine a week ago, over 1,000 miles since and not a squeak.... Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #475259 8th Apr 2018 10:58pm
