Home > Maintenance & Mods (L322) > Front to Rear Brake Lines
RotternEgg
Hi guys
At the moment I'm considering send the RR back to the dealer I bought it off a few weeks ago as there is a brake fluid leak on the front to rear lines, they look pretty corroded and I'm surprised it passed the mot in February as this hasnt just happened overnight.
But my question is has anyone replaced these brake lines before? Its the ones that run under the plastic trim in the pic - which I cant get off either at the moment!
Post #475894 15th Apr 2018 11:04am
kbald
Ive replced mine quite an easy job if you can get underneath. Its a common problem and joe90 did an excellent write up guide which i think is in the wiki. Current 2007 TDV8 Vogue Buckingham Blue
Post #475895 15th Apr 2018 11:05am
RotternEgg
Thanks for that, thought I'd already checked out the Wiki!
Assume the process for my 2008 is the same as the 2002 in the wiki?
Post #475896 15th Apr 2018 11:32am
kbald
Exactly the same Thumbs Up Current 2007 TDV8 Vogue Buckingham Blue
Post #475897 15th Apr 2018 11:38am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Yes, they do run above that plastic trim.
I had an advisory on the MOT for the rear brake pipes a few weeks ago so decided to replace them all. When I took the old ones off, I was surprised by how corroded they were. The MOT testers do not take off any trim to inspect the brake lines (unlike MOTs for lorries) so can only go on what they can see. Unfortunately the rear brake lines are so hidden, it is impossible to see how bad they really are.
There is a union behind the rear part of the front passenger side wheel liner. The pipes then run behind that piece of trim (which will come off with some use of penetrating oil) and hides quite a lot of corrosion, then behind a large plastic cover for the fuel tank/fuel filter that comes off with about 8 bolts - some which are a bit tricky to reach (not a bad idea to change the filter at the same time as doing the brake pipes). The o/s pipe then goes up over to the other side and is clipped on with 2 clips to the body shell (and can rust really badly up there).
My advice would be if you have any concern about corrosion on the rear brake pipes, then it is probably much worse than you think. Anything earlier than an 07 is on borrowed time. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #475899 15th Apr 2018 11:49am
If it helps, here is the link to the wiki entry:
http://www.fullfatrr.com/forum/topic25799.html .
Post #475910 15th Apr 2018 3:20pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I have done the job myself following the instructions that Joe90 has referenced in WIKI. If you are Ok with spanners it is an easy job, but it is not a quick job.
Given you have only just bought the RR, I would put is back to the supplying dealer and get them to fix it. I would expect them to do it free as well as this is a safety issue they should have picked it up in their pre sale inspection. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #475951 15th Apr 2018 9:20pm
Clabs
I'm with Andy - as you only just bought it, and it is actually leaking, then take it back to the dealer you bought it from and get them to sort it. Current Cars:
MY11 5.0 SC Stornoway - sold
MY06 TD6 Zambezi - sold
1997 BMW E36 M3 Evolution Convertible Estoril
Post #475953 15th Apr 2018 9:48pm
RotternEgg
Thanks Gents.
Been on to the dealer and he has offered to pay for the repairs, quite surprised and restored some faith in used car sales companies. Just need to send him a price and he'll pay garage direct.
Post #476006 16th Apr 2018 3:31pm
Zebedee
It's not only the old cars that need attention to brake pipes... These are from a '10 plate I saw today.
 Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #476678 24th Apr 2018 8:35pm
