![]() | Home > Maintenance & Mods (L322) > TDV 4.4 oil drain refitting? |
tomass311 Member Since: 11 Apr 2018 Location: presov Posts: 2 ![]() ![]() ![]() |
Hi, did you figure out this thing? I have same issue, i got the oil change and I think that before the chage it was deeper inside. Thanks for response |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
thats very helpful nino.. |
Thanks a lot |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
ScubaVogueSE Member Since: 07 Apr 2019 Location: Kent Posts: 29 ![]() ![]() ![]() |
Hi. Im trying to drain the oil.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Very hard squeeze and wiggle and pull of the two recessed tabs all at the same time.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Or buy a vacuum pump and suck it out via the tube on top of engine. So much easier and cleaner.
Thank you. Managed to get the bottom plug thingy off and back on again. Hope it doesn't leak.
