![]() | Home > Maintenance & Mods (L322) > Condensation on spare wheel?? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
The compressor is meant to have a drier in it that deals with the moisture within the air system ... so shouldn't affect the outside of the compressor much.
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 236 ![]() ![]() ![]() |
Before I bought my L322 I knew it wouldn’t get used everyday so I talked to my local Indy about it’s storage. One point he made was condensation and damp and how it can effect the electrical components in these vehicles. He suggested buying some of those little dehumidifier units (plastic tub with polystyrene balls in it), he recommended putting one in with the spare wheel, one in the passenger side boot compartment where all the electrical gubbings are and then just leaving one somewhere within the cabin area. I picked a pack of 6 of the dehumidifiers up from ASDA for about £4.00. They’ve been in the vehicle about 3 months now, although there’s no signs of water in the bottom of the plastic container section all 3 are doing there jobs as the polystyrene balls are starting to become rock solid.
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
I've used these in various classic cars over the years with good results.
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Thanks for replies, got some of those cheap dehumidifier tubs ( Yorkshire Trading) £1 each , so ill bung them in and see what happens , might take a bung out or modify it with cut out as well and see when it rains again ( no doubt won’t have to wait long) |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
A Rear cargo area opening seal has been known to allow water ingress, I had this problem on mine, after rain, it gets under seal lip and enters the spare wheel compartment. I usually know it has happened when I can smell stagnant water |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Mine leaked from the top of the tailgate where the seam had failed in the metal. Re-sealed it and it has leaked again where the sealing lifted up, but all ok now. Suggest you check the top of yours, it leaked and took out my Bluetooth unit on the second time around as well!
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Mine was the crash bar behind the rear bumper.
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Very useful thread!
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Definitely sounds like a water leak to me |
