Home > Technical (L322) > L322 Guru's please step-in
Kingstang
United States 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Should there be this type of movement on the rear wheel as shown in this video?
2006 Range Rover SC L322
Post #477061 29th Apr 2018 3:02am
p38arover
Australia
I don't recall seeing anything like that when I did the bushes on the rear of my L322.
I can't imagine what has worn so much as to allow that level of movement - except for the Toe Control Arm.
Get under and try it again whilst looking for movement in the Toe Control Arm - items 14 and 19 in this pic:
Quote:
Toe Control Arms
The toe control arm is a forged steel component. One end is fitted with a taper ball joint and the opposite end has a bush pressed into an integral housing.
The bush locates between brackets on the subframe and is secured with a special eccentric bolt, washer and nut.
This allows for the adjustment of the rear wheel toe in. Rotation of the bolt moves the eccentric head within a recessed slot in the bracket, allowing the toe-in to be adjusted within the set limits.
The taper ball joint locates in a tapered hole in the hub and is secured with a nut.
You might want to check the bushes - see the pics in my post here: http://www.fullfatrr.com/forum/topic13469-15.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #477062 29th Apr 2018 5:31am
Wheel bearing borked
Post #477064 29th Apr 2018 7:02am
p38arover
Australia
If it's a wheel bearing, you'll have the same play when you try rocking it top and bottom. Try it. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #477065 29th Apr 2018 7:04am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Could well be a bearing looking at the state of the inside of the rim. That's had a fair old wack at some point. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #477074 29th Apr 2018 9:59am
verydisco
scary!
what were the symptoms driving it? sound, feel, etc?
cheers l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #477078 29th Apr 2018 10:12am
p38arover
Australia
I don't think it's a wheel bearing, the backplate is moving, too. If it was a wheel bearing, the backplate wouldn't move. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #477083 29th Apr 2018 11:24am
Kingstang
when you apply the brakes there is a loud pop, this happens going forward or in reverse..........It definitely sounded like it was coming from the passenger side right rear.
Post #477084 29th Apr 2018 11:24am
Kingstang
I'll give that a try today.
Post #477085 29th Apr 2018 11:26am
Do not drive it!
Jack up safely and remove the wheel. With that much movement it shouldn't be too difficult to identify where the freeplay is coming from.
If it is not the wheel bearing, then as others have indicated, probably your upper and lower hub bushes and the toe control arm. They are the only three things attaching the hub to the subframe. With the wheel off you will be able to see. .
Post #477110 29th Apr 2018 5:11pm
ooer duplicate post Sad .
Post #477113 29th Apr 2018 5:16pm
p38arover
Australia
Any progress? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #477396 2nd May 2018 11:46pm
Kingstang
I've got the toe control arm off, well at least at tapered ball joint which was very sloppy. The other end i'm dealing with a seized bolt that I need to cut. Hopefully I will tackle this tomorrow.
Post #477560 5th May 2018 3:50am
holidaychicken
I had to cut through the bolt either side of the arm with an air hacksaw but it took a while, a 1 mm cut of disc might have been better but I was concerned about how close to the petrol tank I was
Post #477561 5th May 2018 6:29am
Kingstang
p38arover wrote:
Any progress?
Well replaced the toe control arm (require Saw-zall to get that upper bolt out) and the upper hub bushes,still getting the loud popping sound when braking. I'm just going to take it to a shop as I have other hobbies I want to do. Sad
Post #477637 6th May 2018 5:02pm
