Home > Technical (L322) > Tdv8 two stroke oil
Steveo
Tdv8 two stroke oil
Good morning all is any one using two stroke in the diesel on there tdv8 if so how much just when I had my disco 3 it was recommended but I thought I would ask about the tdv8 as it’s a bit more advanced lol
Post #477903 10th May 2018 8:57am
j_rov
Not sure I'd risk it.
I've read that the lubrication benefits are negligible.
http://www.fuelexpert.co.za/2-stroke-oil-i...-study.php __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #477910 10th May 2018 9:41am
talked about this here before and consensus was that it might work in a tractor [disco 3] but not much use on a more tech engine like the TDV8.. ... - .- -.
Post #477912 10th May 2018 9:53am
Sandyt
Thought all doozles were tractors Rolling with laughter
Post #477916 10th May 2018 11:06am
nino_nino
Steveo, I've used 2T for the past 90K km with no ill effects, first time i put 2T car had 86K km, it was immediate gratification, better power, smudnes, sound.. now I use 1/2 L on the full tank of fuel every 4~5 tankfull. if you decide to try use semi synthetic oil.
Nino,
Post #477939 10th May 2018 2:28pm
kbald
I have been using for a few thousand miles now about 400 ml per tank and it seems to be quieter sounding and runs a bit smoother but that could be all in my head though! From what i read it will clean the fuel lines etc and perhaps be easier on the egrs etc so do it incase it has even the smallest benefits for the cost of the stuff its negligable Current 2007 TDV8 Vogue Buckingham Blue
Post #477946 10th May 2018 6:51pm
gettingold
I used to do it and it did get quieter but simply couldn't be bothered measuring the ratio out, so just put the premium Diesel in now and get the same result.
Steve.
Post #478350 14th May 2018 1:38pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I started putting in Dipetane in as I had an issue with a sticky fuel pressure regulator. £1400 for a new high pressure pump if it didn't work. It did and now it goes in every fill up. 2T will give the same lubrication to fuel system. It gets my vote Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478364 14th May 2018 5:04pm
Paul thornton
What is 2t? Two stroke oil I'm guessing.
I've been using redex on my td6 for the last couple of months but I'm open to suggestions if there's a better option ...
Post #478412 14th May 2018 10:08pm
kbald
It is 2 stroke oil yes. Not sure its better than redex just works out a bit cheaper as you can get 5 litres for £10 to £12 or so, maybe slightly more, but only use 400 to 500ml per tank so about 10 tank fulls at £1.20 or less per tank. Might be worth a try to see if it gives similar benefits for a few tanks? Current 2007 TDV8 Vogue Buckingham Blue
Post #478438 15th May 2018 6:49am
Tommy62
Norway 2007 Range Rover Vogue SE TDV8 Java Black
Discussion is good: facts are even better. A test with a diesel engine in the laboratory showed that with 200: 1 interference.
The exclusivity is here:
The results of the study support a view that the practice of dosing diesel with 2-stroke oil is surprisingly ineffective in terms of lubricity and cetane improvements. Engine performance, fuel consumption and emissions were also unchanged; however the use of 2-stroke oil in diesel is potentially harmful to modern diesel injection equipment. Trace amounts of zinc, an element which is found in most 2-stroke oils, are well known to cause injector nozzle fouling and the study measured high levels of injector fouling when the test engine was running on diesel dosed with 2-stroke oil. While the oil industry may not mind the additional revenue from the sale of 2-stroke oil with each tank of diesel, this study demonstrated that it is not in the best interest of the user to do so.
http://www.fuelexpert.co.za/2-stroke-oil-i...-study.php Range Rover L322 TDV8 07
Range Rover P 38 4,6 LPG Autobiography 00
Range Rover P 38 4,6 HSE 00
Post #478449 15th May 2018 9:01am
j_rov
Like i said above ^^^^ Wink __
Land Rover History:
1976 Series 3 2.25
Post #478462 15th May 2018 10:55am
Tommy62
Sorry J-rov , I dont see your attachments here. Sometimes it's a bit quick but we have the same meaning. Smile Range Rover L322 TDV8 07
Post #478486 15th May 2018 4:12pm
