![]() | Home > Technical (L322) > Tdv8 two stroke oil |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Not sure I'd risk it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
talked about this here before and consensus was that it might work in a tractor [disco 3] but not much use on a more tech engine like the TDV8.. ... - .- -.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Thought all doozles were tractors |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I have been using for a few thousand miles now about 400 ml per tank and it seems to be quieter sounding and runs a bit smoother but that could be all in my head though! From what i read it will clean the fuel lines etc and perhaps be easier on the egrs etc so do it incase it has even the smallest benefits for the cost of the stuff its negligable Current 2007 TDV8 Vogue Buckingham Blue |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 286 ![]() ![]() |
I used to do it and it did get quieter but simply couldn't be bothered measuring the ratio out, so just put the premium Diesel in now and get the same result.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I started putting in Dipetane in as I had an issue with a sticky fuel pressure regulator. £1400 for a new high pressure pump if it didn't work. It did and now it goes in every fill up. 2T will give the same lubrication to fuel system. It gets my vote |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
What is 2t? Two stroke oil I'm guessing.
It is 2 stroke oil yes. Not sure its better than redex just works out a bit cheaper as you can get 5 litres for £10 to £12 or so, maybe slightly more, but only use 400 to 500ml per tank so about 10 tank fulls at £1.20 or less per tank. Might be worth a try to see if it gives similar benefits for a few tanks? Current 2007 TDV8 Vogue Buckingham Blue |
Tommy62 Member Since: 05 Jun 2017 Location: Fredrikstad Posts: 12 ![]() ![]() ![]() |
Discussion is good: facts are even better. A test with a diesel engine in the laboratory showed that with 200: 1 interference.
Like i said above ^^^^ |
Sorry J-rov , I dont see your attachments here. Sometimes it's a bit quick but we have the same meaning. |
