Home > Wheels & Tyres > 255/50r20 to 265/50r20? ok to add a little width?
Page 4 of 5 <12345>
There is always the option of learning to park without smashing it into the kerb.... Wink Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #478222 13th May 2018 9:07am
Vogue
Bow down Laughing 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #478225 13th May 2018 9:11am
Vogue
For what it’s worth those pictures with lines are all meaningless when comparing such small variations in height. All manufacturers tyres are different - many do not accord with true tyre sizes. If you compare Michelin and Goodyear’s - there is a massive difference not only in aspect ratio but also Width - historically Goodyear are also known for being wider and Michelin narrower size for size.
If you are comparing pics you need to get all the tyres the same make, all new, same tyre pressure, all pics taken from the same distance, with the car parked on the same surface and obtain the manufacturers data. Otherwise all you are doing is confusing yourself. Plus the width of the line is probably 3-4mm when you scale it out - plus the pics have been doctored in photoshop - you have far too many variables Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #478229 13th May 2018 9:18am
GGDR
i know I know thing is parking these shipping containers we drive isn't easy with a column of angry London couriers, vans, taxis, Ubers waiting impatiently while you line up. Narrow roads with HGV's shoving through mean you want your wheels an inch from the stone, no more. Any more and you risk loosing a mirror. Been sideswiped when parked more than once.
Then you've got the competitiveness of parking spaces meaning aside of the above you've the extra pressure of claiming a space. Which means haste. A tricky one is the long reverse along the kerb because a space comes free back a bit. Left side you've got the kerb, right side a lorry that's just a bit too big. I try to reverse and keep the rears two inches off. Over a distance you can drift in and not notice because you're watching the other 3 corners. Or a double decker bus filling your mirror.
I think I'm better now a year in, probably clocked up most scuffs in the first few months.
I'll get the rims refurbed when I put new rubber on soon (my continentals are on 4mm) and once they're refurbed I want to protect them.
. Cheers, Greg
Post #478230 13th May 2018 9:24am
GGDR
Vogue yes sure it's only a rough guide. I think it's a good thing there's not much in it, I like the 275s that's probably what I'll go for. and not much in it because of all the variables as you say.
. Cheers, Greg
Post #478233 13th May 2018 9:28am
Vogue
Your best bet is to chose your tyre make and size and then get the manufacturers data - that is the best route and only truly accurate route. We have to do it fairly regularly for tractors as the front tyres are smaller than the rear and you have to match up the ratios - countless times we have found that size for size there are massive differences between makes Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #478269 13th May 2018 3:34pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Photos of my Fatty in access mode with 255/55 /20. AT3
 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478355 14th May 2018 2:17pm
Vogue
Proper RR tyres there ! Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #478375 14th May 2018 6:58pm
Grofus
Yep, they get used too. They're great tyres and a way more plush ride than the standard pirelli's.
I'd recommend them to anyone, even city dwellers. Laughing 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478378 14th May 2018 7:13pm
Grofus
For those that want the "filled arch" look here is the difference in the l322 wheel
versus the L405 wheel
You can see a lot less mudguard. Nearly an inch further out in the arch.
(Maybe Stan can turn them the right way up) 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478410 14th May 2018 9:50pm
GGDR
Bit to much chunk for me Grofus, but Thumbs Up Thumbs Up Thumbs Up
Like the wheels too !
. Cheers, Greg
Post #478422 14th May 2018 11:18pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
How's the tyre noise on them, is it noticeable over the standard road tread tyres?
Post #478483 15th May 2018 3:58pm
Grofus
No noise at all. If anything it's quieter as they soak the road imperfections up better. The ride is plush, easily as good as the several Jags I've owned 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #478485 15th May 2018 4:09pm
nino_nino
Mine 275/45/50 General grabber GT-s on a style 18 L322,
and 255/55/20 Goodyear F1 SUV-s on a 502 style L405
Nino,
Post #478888 19th May 2018 2:13pm
dirtymonkey38
Get tyres with rim protection... Also if you are changing the tyre size from what is OEM you will need to inform your insurance. Shouldn't really affect your premium, but they cant use it as a get out clause for an undeclared "modification".
If you change wheels/tyres in winter to a winter set you should notify your insurance of the change, and when you return to your summer set. 2011 RR Autobiography 4.4 TDV8
Post #482512 3rd Jul 2018 6:26pm
Page 4 of 5 <12345>
