Home > In Car Electronics (L322) > Digital TV upgrade (again!)
Travaskas
Hi All,
I have a 2005 L322 and have just purchased what I was told was a direct replacement for my old analogue tuner unit.
It has all plug and play sockets save a small blue 2 pin one?
Everything works, as it should until you turn on the ignition...presumably an issue with the TV in motion inhibitor I guess?
Is there a simple fix to get around this issue? Or am I destined to only be able to view the TV with the engine off!!!
Your assistance is greatly appreciated in advance! Rolling Eyes
Post #478373 14th May 2018 6:45pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
What tuner die you bought? Thanks!
Post #478671 17th May 2018 1:53pm
Travaskas
Hi there,
Thanks for the reply...
Pictures attached of the tuner.
Any help you can offer would be appreciated Very Happy
Post #478704 17th May 2018 7:10pm
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
You need to make sure the handbrake is on and not in gear (although neutral seems to work). You should still get the sound, though, when running with a warning on the screen.
Post #479183 23rd May 2018 12:19pm
Travaskas
Hi,
Thanks...as I said above, the unit works with sound and picture without ignition on.
The problem is when you start the engine...as it then displays the warning page regarding driving whilst in motion?
This is what I need to overcome and have the ability to watch with engine running, but not driving? 🤔
Post #479196 23rd May 2018 3:13pm
nwmgc
I do understand - there may be a problem with the handbrake sensor by the sounds of things. I would have thought you can test that by making sure the handbrake light comes on when you apply. Goodness knows otherwise...
Post #479197 23rd May 2018 3:18pm
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
try the 753 hack but i think you may have to do this every time you turn the engine off
Post #479213 23rd May 2018 6:03pm
Evo290
Did you get your tv module working in the end
Post #590669 8th Apr 2021 5:57pm
Gsxr1250dave
Dont expect a reply it's a x3 year old post and he never posted again after Censored
Post #590688 8th Apr 2021 11:16pm
Evo290
That’s the trouble I think everything I look at on here I’m too late 😂
Post #590693 9th Apr 2021 8:35am
