![]() | Home > General > MOT - A-Holes |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I had similar when i had my 350Z as it had a LSD. found a local MOT center which used pressure plates to test the brakes. At first glance looked like a floor lift but the reversed the car off then drove on with a bit of speed. slammed on an the sensors calculated the brake bias etc. Very clever bit of kit. Will be taking the RR there come MOT time. |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Most people would not be so familiar with the MOT procedure, I wonder how many 4x4 owners get stiffed for faulty breaks, and leave with damage to their 4WD components all because the tester does not follow the correct procedure.
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
surly you transfer box would be smashed to pieces now ? 2007 TDV8 Vogue SE |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
I hope you won't be taking your vehicle in there then! ![]() There is only one correct way to do it and that's with the Decelerometer. My local MOT garage hardly ever does 4x4s but they are well aware of the correct proceedure, and have done it correctly on my Defender. I'm pretty sure drivetrain components are not designed for speed differences between back and front or left and right wheels. |
I suppose an axle diff is easier and cheaper to repair than the centre diff at least. The VOSA instructions speciffically say not to - so fail to understand why the testers do. ![]() |
scene247 Member Since: 16 Sep 2010 Location: London Posts: 126 ![]() ![]() |
Don't know what year the electronic handbrake came in but don't fancy the idea of this being activated at 20mph as stated in the VOSA guidelines. I tried engaging it at a couple of mph only and that was severe enough. Don't know if it would do the car any good either.
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
Guys,
long way for me to go to get a mot test.. |
Scarey,
...and a refund for the diesel ,ferry and the doughnuts i brought on the way.....see you soon stephen. |
sassanach Member Since: 03 Feb 2011 Location: south west Posts: 12 ![]() |
just a quick question from a long time lurker/short time member.are these vehicles vehicles equiped with lsd's in the front or rear or both axles as standard?. |
Middle LS Diff - with 4 channel traction control.
AndyV8ES Member Since: 04 Feb 2011 Location: Warminster, Wiltshire Posts: 2 ![]() ![]() |
Hi all,
[quote="Fox"]
Thats the whole principal of a diffrential aint it? |
