Home > General > MOT - A-Holes
Page 2 of 3 <123>
I had similar when i had my 350Z as it had a LSD. found a local MOT center which used pressure plates to test the brakes. At first glance looked like a floor lift but the reversed the car off then drove on with a bit of speed. slammed on an the sensors calculated the brake bias etc. Very clever bit of kit. Will be taking the RR there come MOT time.
Post #47873 27th Jan 2011 7:44pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Most people would not be so familiar with the MOT procedure, I wonder how many 4x4 owners get stiffed for faulty breaks, and leave with damage to their 4WD components all because the tester does not follow the correct procedure.
The garage needs reporting, and their testers clearly need more training.
Thanks for posting Dan, as now all the FFRR readers (myself included) will look out for this in the future.
JustinP
Gone - Range Rover Supercharged 2006
Post #47912 28th Jan 2011 12:12am
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
i had this discusion with my local tester about a range rover he had on the rollers (p38), he said they use the rollers but never run both wheels at once. he tested one brake then the other (same axle) and compared the readings but never ran both wheels at the same time.
Post #47915 28th Jan 2011 12:34am
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
surly you transfer box would be smashed to pieces now ? 2007 TDV8 Vogue SE
Post #47952 28th Jan 2011 1:31pm
Fox
I hope you won't be taking your vehicle in there then! Shocked
There is only one correct way to do it and that's with the Decelerometer.
My local MOT garage hardly ever does 4x4s but they are well aware of the correct proceedure, and have done it correctly on my Defender.
I'm pretty sure drivetrain components are not designed for speed differences between back and front or left and right wheels.
Post #47956 28th Jan 2011 1:40pm
dan_uk_1984
I suppose an axle diff is easier and cheaper to repair than the centre diff at least.
The VOSA instructions speciffically say not to - so fail to understand why the testers do.
Post #47957 28th Jan 2011 1:42pm
scene247
Don't know what year the electronic handbrake came in but don't fancy the idea of this being activated at 20mph as stated in the VOSA guidelines. I tried engaging it at a couple of mph only and that was severe enough. Don't know if it would do the car any good either.
As long as it wasn't my pride and joy would take great pleasure watching the event though as the tester engages e-brake on road at 20 mph! Think it could be rather surprising and painful as seatbelt locks too... Twisted Evil
Post #47975 28th Jan 2011 4:10pm
Landrover Mad
2003 Range Rover Vogue Td6 Buckingham Blue
Guys,
We have a top of the range MAHA MOT test lane which is used to test Range Rovers all the time, it is important that we set it up by clicking on the "pseudo 4wd" icon as this allows the 2 individual brake rollers to rotate in different directions at the same time, allowing the diff to work as normal, the braking load produced at each wheel can then be measured.
Unfortunately most simple brake testers will not allow you to do this.
Stephen
Post #47986 28th Jan 2011 5:10pm
long way for me to go to get a mot test.. Laughing ... - .- -.
Post #47987 28th Jan 2011 5:15pm
Landrover Mad
Scarey,
There's a cup of tea or a nice pint waiting for you, if you ever fancy visiting!
Stephen
Post #48354 1st Feb 2011 11:44am
...and a refund for the diesel ,ferry and the doughnuts i brought on the way.....see you soon stephen. Laughing
just noticed you have a very unusual white RR, any chance of some pics. Wink ... - .- -.
Post #48358 1st Feb 2011 12:43pm
sassanach
just a quick question from a long time lurker/short time member.are these vehicles vehicles equiped with lsd's in the front or rear or both axles as standard?.
Post #48750 4th Feb 2011 1:35pm
dan_uk_1984
Middle LS Diff - with 4 channel traction control.
The later models have a lockable rear diff.
Post #48751 4th Feb 2011 1:39pm
AndyV8ES
2003 Range Rover HSE 4.4 V8 Alveston Red
Hi all,
Newbie to the forum! Saw this post and thought and had to comment!!!
I have been going to Riverway MOT for years and have never had a problem. I have had a fair few range rover classics and discoverys 1+2 mot'ed there.
Not to mention my present L322 and previous mot'ed there with out an issue.
Post #48760 4th Feb 2011 2:28pm
AndyV8ES
[quote="Fox"]
Thats the whole principal of a diffrential aint it?
Post #48777 4th Feb 2011 2:58pm
Page 2 of 3 <123>
