![]() | Home > Maintenance & Mods (L322) > How cold? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8061 ![]() ![]() ![]() |
It deteriorates over time - you can get it re-gassed
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Thanks, @Alistair.
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
After a few mins on coldest setting it should be too cold. If i remember correctly 6 degrees celcius __
Dodgy compressor - or leaking refrigerant are the 2 most likely culprits, but if the main dealer thinks it's fine & you don't then you'd need to take it somewhere else for them to test I guess |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I have same problem and it looks like this is the culprit,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Have you got the button with the snowflake on it illuminated? John
Thank you all for your comments.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
On the 2011, its just the button marked A/C on the left hand side - the amber light should be lit - funnily enough I was thinking the same thing the other day - mine wasn't particularly cold, but then I did notice the A/C button was off. D'oh Current Fleet:-
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
You will need a “Black light” to see the leak detection fluid as it is Ultra Violet sensitive fluid. David Please let me know if my comments upset you, I may wish to upset you again. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Take it to an air con specialist if you have no joy with the dealer....
I have that button, thanks ![]() And light is lit. Makes very little difference though. Calling stealer first thing Monday. If there’s a leak it must be a big one ... ... or the problem is something else as kind folk have suggested. What do I put here then? |
