Home > Maintenance & Mods (L322) > How cold?
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
How cold?
Even with my aircon set to the coldest setting (16 degrees), the air is - at best - cool not cold.
Is this right?
The wife's Ewok pumps out lots of cold air at 16 degrees. What do I put here then?
Post #479881 1st Jun 2018 3:05pm
It deteriorates over time - you can get it re-gassed
Or you may have a problem with it......
Post #479887 1st Jun 2018 3:33pm
GAC23
Thanks, @Alistair.
I should have said I've just had it regassed.
Main stealer reckons it's working properly.
I can't believe it doesn't blow out nice icey cold air.
Surely it should? What do I put here then?
Post #479888 1st Jun 2018 3:40pm
j_rov
After a few mins on coldest setting it should be too cold. If i remember correctly 6 degrees celcius __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #479889 1st Jun 2018 3:42pm
Dodgy compressor - or leaking refrigerant are the 2 most likely culprits, but if the main dealer thinks it's fine & you don't then you'd need to take it somewhere else for them to test I guess
Post #479890 1st Jun 2018 3:46pm
nino_nino
I have same problem and it looks like this is the culprit,
it is solenoid controlling swash plate in the compresor. it is held by cercle clip, but it is facing engine block, unfortunately, so it necessitates compressor removal. Big Cry .
Nino,
Post #479891 1st Jun 2018 3:47pm
Weegie
Have you got the button with the snowflake on it illuminated? John
GAP iiD BT-Sold
Post #479892 1st Jun 2018 3:49pm
GAC23
Thank you all for your comments.
In the stealers defence, they regassed and put some dye in to look for leaks.
I can't spot any leaks so it's more likely something else.
Will get back onto them now.
Oh and I don't have a snowflake button - unless I can't see for looking. What do I put here then?
Post #479894 1st Jun 2018 4:00pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
On the 2011, its just the button marked A/C on the left hand side - the amber light should be lit - funnily enough I was thinking the same thing the other day - mine wasn't particularly cold, but then I did notice the A/C button was off. D'oh Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #479906 1st Jun 2018 7:24pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
You will need a “Black light” to see the leak detection fluid as it is Ultra Violet sensitive fluid. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #479908 1st Jun 2018 8:14pm
mjdronfield
Take it to an air con specialist if you have no joy with the dealer....
If you have 4 zone air con it needs more refrigerant than one without, so make sure they have regassed it with enough gas if yours has separate rear A/C
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #479909 1st Jun 2018 8:48pm
GAC23
I have that button, thanks Smile
And light is lit.
Makes very little difference though.
Calling stealer first thing Monday.
If there’s a leak it must be a big one ...
... or the problem is something else as kind folk have suggested. What do I put here then?
Post #479929 2nd Jun 2018 10:42am
