Home > Technical (L322) > VIN decoded - some questions about what was revealed
Kiwimac
New Zealand 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I put my RR VIN through one of the online decoders, which came up with a long list of the options etc fitted on the car.
Some of them were not entirely clear to me and I wondered if anyone here could shed any light (the vehicle is a 4.2SC 2006 model registered in 2007 in Japan, then imported into NZ pre-owned later)
1) Door Locking Mode - Remote central locking [076DI]; Market Constraint - Order Restriction JAP [201AJ];
2) Locking Radio Frequency - Infra Red Remote Control [076DW];
3) Hot / Cold Climate - Hot Country Version [072AJ
4) Trim Rear - Trim Rear - High Line [154AB]
Can anyone shed any light on these?[/list][/list]
Post #481055 16th Jun 2018 12:16pm
Beausoleil
The same parameters for a UK registered 2007 Vogue SE I have access to are:
Locking Radio Frequency - 433.92 MHZ frequency (normal) [076DF];
Market Constraint - Order Restriction GBR [201AA];
Trim Rear - Trim Rear - High Line [154AB];
So I would suggest that your Japanese market car’s remote locking/unlocking mechanism is the same but requires line-of-sight to operate (maybe the 433.92 MHz radio frequency is/was restricted in Japan). Presumably the “Market Constraint” item simply refers to the intended market (JAP vs GBR) and the “Trim Rear” to one of two or more levels of rear cabin upholstery. It is reasonable to assume the entry level model is less well appointed in this regard.
The “Hot/Cold Climate” parameter did not come up for the TDV8 car I checked, so perhaps cars intended to operate in warmer climates had boosted cooling systems. I’m just guessing but I’m sure someone better informed will respond soon.
Post #481115 17th Jun 2018 5:42am
Kiwimac
Thanks - that makes sense.
I think it is a BMW based locking system as it has the 'Clown Nose' on the bottom of the rear view mirror which I recall seeing in BMW's of a certain age.
Post #481116 17th Jun 2018 5:44am
Beausoleil
On EU BMWs that's just a sentinel that flashes to signify the alarm is set. If yours doesn't flash, I suppose it could be an IR receiver. The test is, can you unlock your car without it 'seeing' your remote.
Post #481144 17th Jun 2018 11:30am
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Can I ask which online decoder you used, as I have tried the recommended Topix system and it could not decode anything other than basic information? David
Please let me know if my comments upset you, I may wish to upset you again.
Post #481146 17th Jun 2018 11:36am
Beausoleil
I believe it was vindecoderz.com or something very similar. It was a little jumbled and some of what came back was in what looks like Russian.
Post #481148 17th Jun 2018 11:42am
Boxbrownie
Thank you, I must admit I did look at that site but got nervous about bugs/hacks etc.
I shall look again Thumbs Up David
Post #481149 17th Jun 2018 11:52am
Google Translate does a pretty good job of handling all the Russian text, but put it in in chunks as there is a text number limit. .
Post #481150 17th Jun 2018 12:19pm
Beausoleil
Way ahead of you Joe and yes it was surprisingly good. None of it told me anything much, though and most was just repeating the English.
Post #481152 17th Jun 2018 12:25pm
