![]() | Home > Technical (L322) > VIN decoded - some questions about what was revealed |
Kiwimac Member Since: 15 Jun 2018 Location: Wellington Posts: 48 ![]() ![]() ![]() |
I put my RR VIN through one of the online decoders, which came up with a long list of the options etc fitted on the car.
Thanks - that makes sense.
Beausoleil Member Since: 29 May 2018 Location: London Posts: 7 ![]() ![]() ![]() |
On EU BMWs that's just a sentinel that flashes to signify the alarm is set. If yours doesn't flash, I suppose it could be an IR receiver. The test is, can you unlock your car without it 'seeing' your remote. |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
Can I ask which online decoder you used, as I have tried the recommended Topix system and it could not decode anything other than basic information? David
I believe it was vindecoderz.com or something very similar. It was a little jumbled and some of what came back was in what looks like Russian. |
Thank you, I must admit I did look at that site but got nervous about bugs/hacks etc.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
Google Translate does a pretty good job of handling all the Russian text, but put it in in chunks as there is a text number limit. .
Way ahead of you Joe and yes it was surprisingly good. None of it told me anything much, though and most was just repeating the English. |
