Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED
Page 2 of 7 <1234567>
GraemeS
Australia
Subscribe to Topix and download either just the 4.4 engine section or better still, download the lot.
Post #481575 21st Jun 2018 9:52pm
Salter121
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Sumatra Black
Thanks; just subscribed to Topix; very useful.
Post #481589 22nd Jun 2018 6:10am
GraemeS
Australia
Be sure to fit the updated secondary turbo drain pipe(s) if not already retro-fitted to the old engine. The new engine should have the hole in the side of the block pre-drilled, unlike the engines originally fitted to the L322 and early L405 which required a hole to be drilled into the side of the block whilst still filled with oil.
Post #481590 22nd Jun 2018 6:57am
Baltic Blue
The TSB with all the details of the turbo drain mod is in the WIKI.
Post #481592 22nd Jun 2018 8:22am
Baltic Blue
You might want to look into the oil feed pipe to the turbo’s.
Many 2011/2012 owners on here have replaced the O rings to repair a rear of engine oil leak, but it is worth knowing that later cars have a modified pipe, but, sorry I don’t know what changed.
Post #481641 22nd Jun 2018 9:20pm
dirtymonkey38
Watching with interest 2011 RR Autobiography 4.4 TDV8
Post #482110 28th Jun 2018 5:25pm
Salter121
The new engine is now being fitting with all the ancillary parts from the old engine and having the sump's swapped as this is an engine intended for an L405.
Once we got all the parts out of the car we realised that the turbo's were missing.... Shocked
Having all the injectors tested.... hope they don't need replacing.
what a jigsaw.
Anyway; just purchased two new turbo's..... what have I got myself into!
With all the bits removed, you can see from the pics that it's been sitting for a while....
Post #482513 3rd Jul 2018 6:28pm
dirtymonkey38
Your braver than me, very interesting project though. 2011 RR Autobiography 4.4 TDV8
Post #482515 3rd Jul 2018 6:30pm
Salter121
Few images of the old engine
Post #482516 3rd Jul 2018 6:33pm
dirtymonkey38
Is there any benefit to using an engine from the L405? 2011 RR Autobiography 4.4 TDV8
Post #482517 3rd Jul 2018 6:34pm
Salter121
They are the same engine to the most part; though the sump is different and all the ancillary set up; but the bare long engine its the identical ford engine baring the sump.
Post #482518 3rd Jul 2018 6:47pm
Salter121
Post #482519 3rd Jul 2018 6:48pm
Paul thornton
You're a brave man! Hope it all works out.
Car looks lovely by the way.
Post #482523 3rd Jul 2018 7:23pm
Salter121
Had all 8 injectors tested today and 7 need replacing / refurbing Crying or Very sad . Just looking at the cost of this; is there a real difference between the Land Rover ones and the OEM’s such as AllMake; which seem to be the cheapest - cheaper than refurbish the old ones....I wonder if they have the exact same flow rate. Anyone know?
Post #482638 4th Jul 2018 7:22pm
Baltic Blue
I don’t know if their is anything special about 4.4 tdV8 injectors, but I have had a couple of sets of Td6 injectors refurbished at a Bosch service centre in the past and they were as good as new at a fraction of the cost .
Post #482641 4th Jul 2018 7:44pm
