![]() | Home > Technical (L322) > 4.4 TDV8 - changing fuel filter |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
there is this from the wiki Greg [no pics] but theres no mention of bleeding...
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
ah thanks Stan, I promise I did check the wiki - but missed that one!
Thanks to Emirates380 for his fantastic write ups - the priming STEP 14 sounds about right
Shame his pics have gone - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
ah, i'm embarrassed now...must remember that bleeding can also mean priming.... |
| paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358
There was a similar procedure on my Defender TD5 to kick the fuel pump in and force it to bleed/prime itself after fitting a new filter.
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
its an easy task but the new filter can put up a fight when going on. I cross threaded mine without even realising.
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
I filled my with diesel before putting it back in line. less wait this way.
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
+1 with Nino, i just turned on ignition and waited for fuel pump to stop and then started RR and left it tick over for a few seconds. I had to remove the whole assembly to get the filter off as it was too tight with my sausage fingers!! 2015 4.4 AB
thanks chaps.
I think the official advice is yes but I'm a rebel and didnt |
As its diesel as opposed to petrol I'm tempted to leave it on....
I did not, i did take out air box (held in place by tree rubber grommets) which will give you plenty of space to work. |
Nino you're incredible you seem to have photos and solutions instantly on hand for almost only job on a 4.4.
| All times are GMT |
