Home > Technical (L322) > 4.4 TDV8 - changing fuel filter
GGDR
Hi guys,
One of my service items is my fuel filter which I'l be changing soon.
I've got the workshop manual, looks pretty straight forward.
Interestingly it says disconnect battery ground. On a diesel seems a bit of overkill but fine....
The bit I'm not sure about is that it says :
Refer to: Low-Pressure Fuel System Bleeding - TDV8 3.6L Diesel (310-00 Fuel System - General Information, General Procedures).
Seems there is a bleeding proceedure but I don't have the 3.6 manual, can anyone shed any light?
Cheers! Cheers, Greg
Post #481758 24th Jun 2018 3:45pm
there is this from the wiki Greg [no pics] but theres no mention of bleeding...
http://www.fullfatrr.com/forum/topic35253.html ... - .- -.
Post #481761 24th Jun 2018 4:05pm
GGDR
ah thanks Stan, I promise I did check the wiki - but missed that one!
honest guv!
Thumbs Up Thumbs Up Cheers, Greg
Post #481764 24th Jun 2018 4:21pm
Laughing ...no probs.. Wink ... - .- -.
Post #481765 24th Jun 2018 4:23pm
GGDR
Thanks to Emirates380 for his fantastic write ups - the priming STEP 14 sounds about right
Quote:
14. To Prime the system all you need to do is:
Turn Ignition on WAIT 30 Seconds - DO NOT START CAR
Switch OFF Ignition and repeat
Shame his pics have gone Big Cry
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Cheers, Greg
Post #481767 24th Jun 2018 4:24pm
ah, i'm embarrassed now...must remember that bleeding can also mean priming.... Mr. Green ... - .- -.
Post #481769 24th Jun 2018 4:27pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
There was a similar procedure on my Defender TD5 to kick the fuel pump in and force it to bleed/prime itself after fitting a new filter.
On the Defender you could hear the pump whining away and priming while it was doing it's thing, and then it all went quiet at the end - it always worked perfectly for me Smile.
Post #481910 26th Jun 2018 3:52pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
its an easy task but the new filter can put up a fight when going on. I cross threaded mine without even realising.
take your time Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #481917 26th Jun 2018 4:29pm
nino_nino
I filled my with diesel before putting it back in line. less wait this way.
Nino,
Post #481961 27th Jun 2018 8:33am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
+1 with Nino, i just turned on ignition and waited for fuel pump to stop and then started RR and left it tick over for a few seconds. I had to remove the whole assembly to get the filter off as it was too tight with my sausage fingers!! 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481963 27th Jun 2018 9:25am
GGDR
thanks chaps.
So shall I disconnect the battery?
I'll need it back on straight away for the priming.
. Cheers, Greg
Post #481971 27th Jun 2018 10:58am
dolph34
I think the official advice is yes but I'm a rebel and didnt Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481976 27th Jun 2018 11:49am
GGDR
As its diesel as opposed to petrol I'm tempted to leave it on....
. Cheers, Greg
Post #481980 27th Jun 2018 11:55am
nino_nino
I did not, i did take out air box (held in place by tree rubber grommets) which will give you plenty of space to work. Very Happy
last one is on the bottom.
Nino,
Post #481987 27th Jun 2018 12:38pm
GGDR
Nino you're incredible you seem to have photos and solutions instantly on hand for almost only job on a 4.4.
. Thumbs Up Thumbs Up Thumbs Up Cheers, Greg
Post #481988 27th Jun 2018 12:50pm
