Home > Technical (L322) > 2011 4.4 tdv8 alternator problems
Page 4 of 6 <123456>
nino_nino
did battery disconnect and touch the + - cables. this is what I have now Very Happy :
started the car number of times, drove for 1/2 hour it is holding steady. Very Happy Very Happy Very Happy
Nino,
Post #481537 21st Jun 2018 2:11pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Thats want you want to see Nino , however according to LR the alternator gives its max charge on deceleration, does your alternator amps increase during deceleration ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481578 21st Jun 2018 10:12pm
Baltic Blue
Nino,
Please guide me through the iid update process.
I am away from home today, but intend to try and update mine over the weekend.
Cheers
Post #481598 22nd Jun 2018 9:28am
nino_nino
Mike, unfortunately I was unable to make update work. I remain with tested values only. As per Pat's instruction I connected module to computer and pair it with phone app which then opens in a bootloader mode. pres bootloader arrow and it downloads some files but to no avail. I even reinstalled app on all four of my devices (galaxy s5, 7, 8, notebook) no luck.
Nino,
Post #481621 22nd Jun 2018 4:11pm
Baltic Blue
Nino & John,
I have given up on trying to update my iid.
My laptop is not very good and I rarely use it these days, preferring to use my iPad.
These are the readings with the old battery before I buy a new one.
A friend has offered to help me lift the old one out etc, so I will start looking for one.
Any tips re- changing it ??
Cheers
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #481823 25th Jun 2018 11:55am
dolph34
Hi Mike , i think the bonnet needs to be in service / access mode and then it's straight forward enough.
Regards, John 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #481825 25th Jun 2018 12:43pm
nino_nino
.this is what I did Mike, haveing to change batery by my self and okvard position of batery plus waight thare is big chance of f Censored g ones back. so I divised litel helper Very Happy :
I removed cabin air filter housing first( more room to move around), then remove cable ties circle in red and two bolts holding cable harness cover I was able to swing CU without disconnecting it.( 4.4 TDV8 CU has no cooling fan on the beck.) with this CU can be sving out of the way and bateri is ready to be removed. Pictures tell the story:
Nino,
Post #481840 25th Jun 2018 2:28pm
nino, thats a useful 'contraption'...can you re-post in a new thread so i can stick it in the wiki .. ... - .- -.
Post #481841 25th Jun 2018 2:43pm
Baltic Blue
Thanks for the idea Nino.
I have just been looking at the job and can see that will be a big help, even with 2 people.
Cheers
Post #481842 25th Jun 2018 2:57pm
nino_nino
Stan, i think it would be best if you can move my post to the excellent battery replacement by "scuddriver" already in WIKI that way it is all in one place.
Nino,
Post #481846 25th Jun 2018 4:01pm
done nino... Wink ... - .- -.
Post #481849 25th Jun 2018 4:26pm
nino_nino
Post #481850 25th Jun 2018 4:48pm
mpirie
Is that one of those JLR "special" tools we hear so much about? Rolling with laughter
Wish I'd thought of that before giving myself a hernia during my last battery swap! Big Cry
Nino - keep an eye out in case JLR try to knick your idea! Thumbs Up
Mike
Post #481878 26th Jun 2018 9:38am
nino's wooden bridge could be handy if you're doing work right at the back of the engine... ... - .- -.
Post #481880 26th Jun 2018 10:37am
nino_nino
Wait till You see my next "tool" - this one I may sell thru Stan for the benefit of this friendly forum. Very Happy
Nino,
Post #481882 26th Jun 2018 10:41am
