Home > Technical (L322) > How to reset your Service Indicator
4rovers
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
Thanks,
that worked Wink
Post #46892 21st Jan 2011 3:22pm
phillh
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
2002 Vogue V8.
Worked first time, many thanks!
Laughing
Post #48225 30th Jan 2011 8:04pm
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
Larry wrote:
Didn't work on mine!
Found this (below), is slightly different procedure, maybe this will work on someones car:
Resetting the Oil Service or Service Interval Message.
Ignition key must be “off”.
• Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
• Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: “OIL SERVICE, or “INSPECTION”, with “reset”.
• Release the reset button and press and hold it again until “reset” begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: “END SIA
Did this on mine last night, but the actual interval never changed. Which leads me to suspect that it might actually have had an oil change recently - the oil wasn't properly black. The cabin air filter was, though. Rolling Eyes
Post #127940 27th Jun 2012 12:33pm
http://www.fullfatrr.com/wiki/Secret_Codes
This does work... try again. How will the car know the oil is not black yet ? Wink
But before you try, why reset it if it apparently doesn't need resetting? Or does it? .
Post #127948 27th Jun 2012 1:44pm
misteralz
Well, I'm happy enough changing the oil and filters again in a year or 8,000 miles, but I'd rather tell the car it's been done than leave it and find it's telling me it needs serviced when I may have just done one if I hadn't reset it.
That made sense to me in my head, but written down... Laughing
Post #127957 27th Jun 2012 2:14pm
Laughing Thumbs Up .
Post #127979 27th Jun 2012 3:50pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
I was trying to do my 52 reg the other day but couldn't do it , bet I need the drivers door open too
Post #447544 11th Aug 2017 7:27pm
beep-beep
Ireland 2007 Range Rover Vogue TDV8 Buckingham Blue
Tried restetting the service indicator on my 07 3.6 Range Rover but no good with the mileage reset and door open etc etc. Presume you need to plug it in?
Post #481747 24th Jun 2018 1:09pm
Weegie
07 needs to be plugged in - dealer or iiD. John
GAP iiD BT
Post #481748 24th Jun 2018 1:18pm
vogue16
France
hi guys
i got a 2005 vogue 4.4 petrol with the jag engine
tried to reset the indicator by all methods, nothing worked, even the IIDTOOL..
dealer only i guess ? Current: L322 TDV8 4.4
Post #487268 27th Aug 2018 1:56pm
l322novice
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Service Reset Tool
Anybody tried this?
http://www.diagnostic-world.com/pages/iCar...129341.cfm
or
http://www.diagnostic-world.com/pages...
Post #494716 5th Nov 2018 5:06pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I’ve been considering this since acquiring a 2010 model.
http://www.launchtech.co.uk/enthusiast-dia...ofessional Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #494718 5th Nov 2018 5:43pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I just have my 2006 AJV8 serviced every 12,000 miles or every year whichever is first (normally around 10,000 miles) but have never had any service message comeup in the 5 years / 62,000 miles I have owned it. Is it possible that a P/O has turned off teh service indicator somehow? There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #501096 10th Jan 2019 11:13am
