![]() | Home > Maintenance & Mods (L322) > First of many questions |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6426
Please fill in your profile so we know what car you have got!
| Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56
Thanks Joe for a quick response
very smart |
thanks again
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259
Your offside exhaust leak will be a crack in the front edge of the cat where the manifold comes down from the engine and enters the catalyst. Well known fault but can be welded for c. £50
dolphinboy
NOt an expert in this but know from others they have had probs getting bits off etc. due to age and corrosion.
| bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69
Oil leak is probably the valve cover gaskets - common problem, replacement seals are about £30 but get them replaced by an independent specialist - could also be the PCV valve causing pressure and forcing oil under the seal. |
