Home > In Car Electronics (L322) > navcoder help required please
Shambler
Hi, so I’ve got a registered version of Navcoder, I’ve tried to read the radio, tv and Navigon units but it just keeps coming up with check interface connections and make sure device is switched on?? Can anyone shed any light as to what I’m doing wrong??
Post #482352 1st Jul 2018 5:56pm
dirtymonkey38
Is it USB to serial adapter? Could be the driver on the pc your using or maybe an incompatible chipset in the USB adapter? 2011 RR Autobiography 4.4 TDV8
Post #482359 1st Jul 2018 7:42pm
mjdronfield
I had a few issues with USB...you have to use the same socket you used when you set it up. My issues were PC related...not the car.... worth a check. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #482362 1st Jul 2018 8:08pm
Shambler
I’m using a usb to obd port adapter that I got from flea bay, it came with a disc but can’t seem to get the disc to load so maybe that is the problem, any idea where I might down load drivers from?
Post #482364 1st Jul 2018 8:21pm
dirtymonkey38
Try windows update. Any chipset info on the item you won? You could try searching for them on google if you have that info 2011 RR Autobiography 4.4 TDV8
Post #482373 1st Jul 2018 9:24pm
Shambler
To be honest I’m not a computer wizard and wouldn’t know about chipsets etc lol, laptop is only about a year old and up to date I believe 🤓
Post #482376 1st Jul 2018 10:01pm
dirtymonkey38
I meant the chip in the serial adapter. Have you got a link to the one you bought? I’ll have a look for you 2011 RR Autobiography 4.4 TDV8
Post #482379 1st Jul 2018 10:22pm
Shambler
I’ll try and find it, I bought it a month or so ago and don’t think the same are on Ebay anymore though there are a couple similar, give me a moment and I’ll see what I can find 👍🏻
Post #482382 1st Jul 2018 10:29pm
Shambler
Post #482383 1st Jul 2018 10:36pm
Shambler
I’m not sure how to do a link thingy so I took a screenshot of it 🤣
Don’t know if you can tell anything from that tho’ 🤞
Post #482384 1st Jul 2018 10:41pm
p38arover
Australia
I've had no problems but I'm using the Resler interface.
http://www.reslers.de/IBUS/index.html Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #482387 2nd Jul 2018 12:19am
dirtymonkey38
looks like that plugs into the OBDII socket. I had the Resler unit that connected to a USB serial adapter that then plugged into a cable you disconnected from the nav unit. Serial adapter chipset was finicky and had to be FDTI compatible. With yours plugging into the ODBII port I'm not sure....its either the drivers on the PC or com port needs setting.right click my computer\
Might be worth contacting the seller for driver download link first off. Also check comm port by clicking start\manage
When computer management pops up click on device manager in the list on the left hand side and have a look through there to see if there are any exclamation marks next to anything, also look under "ports (COM and LPT)
Does the software open? you may be able to check comm port settings in there too. 2011 RR Autobiography 4.4 TDV8
Post #482395 2nd Jul 2018 8:28am
dirtymonkey38
by the way, what is it you are trying to do with navcoder? 2011 RR Autobiography 4.4 TDV8
Post #482396 2nd Jul 2018 8:28am
mjdronfield
I think the cable you buy has to be compatible with navcoder....that one looks like it comes with its own diagnostic tool.....might be wrong....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #482437 2nd Jul 2018 6:18pm
Shambler
Just trying to set a few bits n bobs, tv etc and supposedly I can use it for setting up Bluetooth for the phone etc when I’ve fitted it?
Post #482444 2nd Jul 2018 8:28pm
