Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED
Page 3 of 7 <1234567>
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
We all are going to learn a lot from this exercise!!!
Good Luck Thumbs Up Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #482642 4th Jul 2018 8:22pm
GraemeS
Australia
The 4.4 injectors have 8 holes whereas 3.0 TDV6 injectors, at least early versions, had 7 holes so don't get caught with inferior versions.
Post #482666 4th Jul 2018 10:20pm
Frans@Yamorna
On the v8 each injector look after 550cc while on the v6 only after 500cc.I doubt if the v6 injectors will work.Volume needed is 10% more. 2012 TDV8 Vogue SE 4.4
Post #482678 5th Jul 2018 8:24am
Salter121
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Sumatra Black
8 new Bosch injectors LR066229 ordered; only needed Seven; but it just seems worth doing all of them. It is now officially a money pit!
Post #482705 5th Jul 2018 7:44pm
fisha
A range rover is always a money pit! V8 or else ...
Post #482747 6th Jul 2018 12:31pm
Salter121
As I mentioned before; I am fitting the same L405 4.4 ford TDV8 engine into my L322; one of the ket main engine differences is the sump..... turns out the sump on my old L322 is damaged
......does anyone know if you can actually put the L405 sump in the L322? otherwise; another £900+ for a new one.
Post #483912 20th Jul 2018 4:53pm
Salter121
Post #483913 20th Jul 2018 4:55pm
Salter121
This has been a very slow going project with endless hurdles.
Post #489678 23rd Sep 2018 2:57pm
Salter121
Post #489679 23rd Sep 2018 2:57pm
Salter121
Post #489680 23rd Sep 2018 2:58pm
Salter121
Nice to see the engine finally in the car.
Post #489681 23rd Sep 2018 2:58pm
Salter121
This really is a jigsaw puzzle for grown-ups; and impossible to know what was actually missing when I first got the car. As the work has commenced it has become apparent that there was a lot of items missing. We did a full checklist when the car first arrived; I can't believe it but did realise the exhaust had been removed and was not present until last week. The complete system from the manifold back. So that is now on the top of the list to locate....
Post #489682 23rd Sep 2018 3:02pm
Salter121
If anyone can recommend where I might find a complete exhaust system; I've been doing the rounds with the breaker and of course eBay. I actually found one last week; however, was a day late as the breaker/seller had just cut it to sell the catalytic converter separately.... the search continues.
Post #489683 23rd Sep 2018 3:06pm
there is a specialist Range Rover / Land Rover breaker on the A38 near Burton on trent. Not used them but I drive past them occasionally.
They are called Hi-Range, so have a google of that in Burton on trent and give them a call. As its a 4.4 its probable that they won't have one but worth a try. There is nothing that can't be fixed with a hammer😜😜
Post #489686 23rd Sep 2018 3:28pm
GGDR
I know the last thing you need is another, but what about buying a Cat D as a donor?
Might be auctions rather than breakers?
. Cheers, Greg
Post #489692 23rd Sep 2018 4:17pm
