![]() | Home > Technical (L322) > Air Susp. Inactiv, no lights on the console |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Maybe a leak in the reservoir? 2015 4.4 AB
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
compressor exhaust filter clogged up?? ... - .- -.
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
Hi Stan,
this relates to the suspension being stuck in off road height but it can also possibly be your problem,
What is your reservoir pressure like?
I'm getting a tool at the weekend so that I can monitor it and try and figure it out. |
Sandy Choda Member Since: 05 Sep 2017 Location: Stafford Posts: 17 ![]() ![]() ![]() |
I'm struggling with the same fault. Mine's stuck in Off Road height with system shut off after having burst a front airbag... The good news is that it's holding its height now
are your air bags ok now???
We were trying to check the suspension so went to Off road height and the bag burst. I then replaced the air bag but on standard height on the control panel the car is still sitting at off road height. After a short drive the system has read abnormal heights and gone into hard fault shut down.
Update: following the code clear yesterday the car has been perfect. I did about 130 miles today and it slipped seamlessly in and out of motorway mode. I had to put it to access mode in a multi-storey car park and it managed that no problems.
Hmm this error has reappeared after two months of perfect driving. Cleared but it seems to be reappearing instantly I’ll have to investigate further tomorrow |
Air bag on the other side, or other axle ?
Airbags seem fine as it is maintaining pressure. I think it’s a reservoir issue. |
