![]() | Home > Technical (L322) > TD6 Gearbox, not changing Gear |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
| daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107
cheers Phil makes sense,but the oil was like new and no filings at all in the oil or magnet,which i would have thought would be there if the shaft was broken. Mercedes AMG w207
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
Did you replace the torque converter, or is it the original?
The Torque Converter looked like its was a week old lol so used the one supplied with the replacement gearbox,the gearbox is so so smooth to my old unit but just wont change,what do you mean by clutch lock up is this a solenoid driven part ? Mercedes AMG w207
Anymore advice please. Mercedes AMG w207
Sorry for the delay in replying, I've been away.
| Bobthebuilder4470 Member Since: 23 Mar 2018 Location: Islay Posts: 5
My gearbox was the same was told it was a shaft inside the box so removed the box and replaced it with the box from an x5
Great thanks i will remove the valve body first and have it checked. Mercedes AMG w207
| All times are GMT |
