Home > Maintenance & Mods (L322) > Rear Diff Oil fill plug, Part No & Position?.
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Planning on changing my diff oils 2006 spec V8 AJ petrol. Normal Diff (ie not electric) & in preparation I'm ordering the drain & fill plugs. (Drain plug is TYB500110, but nothing found on Microcat for the rear fill plug ).
Now I know this sounds a bit daft, but struggling to find the part No for the Rear fill plug & it's position on the diff. From what I can see (bearing mind it's difficult to see at the moment) it appears to be sat on the OS half way up the housing, very small possibly only a 10 mm bung.
I will raise it up to off road height to get a better look where it is, but would appreciate any further information to enable me to obtain the fill plug, Very Happy
Post #483525 15th Jul 2018 8:02pm
GGDR
Just done mine but not sure. Neither is Dan because when (if) you order from Duckworths, you may get the wrong one like me and one other chap.
Just a watch out really.
Excellent guide in the Wiki section.
. Cheers, Greg
Post #483530 15th Jul 2018 9:49pm
p38arover
Australia
Why change the diff plug? In over 55 years of driving and maintaining cars, I've never need to replace a diff plug. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #483542 16th Jul 2018 4:31am
dingg1
what he said , if it comes out it'll go back in
Post #483547 16th Jul 2018 7:05am
GGDR
Something to do with the magnets?
. Cheers, Greg
Post #483548 16th Jul 2018 7:11am
nino_nino
No magnets on the filler plug, and I also have never replaced one. when putin plugs back in use some plumbers teflon tape.
Post #483550 16th Jul 2018 9:28am
Highroller
Thanks for the reply guys. Yes if it comes out ok then I can put it back in, however it's pretty rusty under there & for the cost of these I'll like to replace it or at least have a new one handy.
Still unable to locate any part No, diff appears to be the same as the sport/ super charged & Disco 3 models.
Post #483558 16th Jul 2018 11:09am
p38arover
Australia
I hadn't thought about rust - it's not something that comes to mind here - Land Rovers have an in-built rust prventative system. Very Happy Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #483621 17th Jul 2018 9:47am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
up to vin 2007
Rear diff filler plug i believe is LR054727 size M10x25
drain plug rear new part number 8510276
your plug part number is for 2007 onwards TYP000220 & TYB500110 are both listed description drain plug
Post #483622 17th Jul 2018 10:02am
Highroller
Thanks Lounge_on_wheels. That sure looks like it from what I can see (Obviously it's Not been out for a long time as heavily corroded).
I'll see if I can obtain one. Many thanks.
Post #483666 17th Jul 2018 7:48pm
Highroller
UPDATE:- Still struggling to find this plug & remove the old one Big Cry FTC5431 or TYB500110 is too big (21 mm ).
The rusted / seized one is approx 16 mm with a 8 mm hex. By the way this has now rounded off! & a nightmare to get to.
I will try & hammer a slightly larger alen key in, but if this doesn't work do I weld a bolt on?. Drill out & retap to the larger bung. Change the diff?????????. Censored
Has anyone filled the diff via the breather?. look at this diff on ebay item No eBay Item No. 302814540808 (similar fill plug).
Post #484509 28th Jul 2018 11:36am
Can you get a cold chisel on it to get it going round ? .
Post #484533 28th Jul 2018 2:19pm
Highroller
Cheers Tim, Might have a go at that.
Could really do with it on a ramp, as not a great amount of room under there.
The other problem is getting another one, after this one gets butchered!.
Post #484536 28th Jul 2018 2:35pm
Have you asked Dan at Duckworths, supplied VIN, etc. Usually works, although I see what GGDR was saying above. .
Post #484542 28th Jul 2018 3:41pm
nino_nino
if you gonna bang something in, try Torx bit, oversized, it will have more grip, or cut a groove in the bolt with dremel like tool and use screwdriver with wrench.
Post #484550 28th Jul 2018 6:15pm
