![]() | Home > Maintenance & Mods (L322) > Rear Diff Oil fill plug, Part No & Position?. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Just done mine but not sure. Neither is Dan because when (if) you order from Duckworths, you may get the wrong one like me and one other chap.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1561 ![]() ![]() |
Why change the diff plug? In over 55 years of driving and maintaining cars, I've never need to replace a diff plug. Ron B. VK2OTC
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1371 ![]() ![]() |
Something to do with the magnets?
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
No magnets on the filler plug, and I also have never replaced one. when putin plugs back in use some plumbers teflon tape. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Thanks for the reply guys. Yes if it comes out ok then I can put it back in, however it's pretty rusty under there & for the cost of these I'll like to replace it or at least have a new one handy.
I hadn't thought about rust - it's not something that comes to mind here - Land Rovers have an in-built rust prventative system. |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
up to vin 2007
Thanks Lounge_on_wheels. That sure looks like it from what I can see (Obviously it's Not been out for a long time as heavily corroded).
UPDATE:- Still struggling to find this plug & remove the old one |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Can you get a cold chisel on it to get it going round ? .
Cheers Tim, Might have a go at that.
Have you asked Dan at Duckworths, supplied VIN, etc. Usually works, although I see what GGDR was saying above. .
if you gonna bang something in, try Torx bit, oversized, it will have more grip, or cut a groove in the bolt with dremel like tool and use screwdriver with wrench.
