Home > Technical (L322) > Siemans VDO mystery box
L7APK
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Ok, was having a root around behind the removable panels in the boot, like you do when you've got a new (to me) car.
Behind the drivers side panel, to the rear side of the fuse box, I noticed a wiring loom with a connector , not connected to anything, then I spotted the white box. It say
Siemens VDO 5WK10250C BMW 61.35-6 955 253. Now the simple solution would be to plug it back in, but it has'nt unplugged itself and i'm not sure if its the self distruct device.
Does anyone know what its for ?
Post #48377 1st Feb 2011 4:42pm
i think its the control module for the tow bar electrics. ... - .- -.
Post #48379 1st Feb 2011 4:58pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Yes it is the control module for the towbar electrics. Do you have a towbar fitted? if not it may have been removed by the previous owner... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #48382 1st Feb 2011 5:23pm
L7APK
Yep, theres a tow bar fitted, it has both the standard black socket and the caravan one. I got the detachable tow ball out and its never been used, if the opinion is that its the towbar electric module , i'll give it a go tomorrow.
Post #48385 1st Feb 2011 6:32pm
mzplcg
Definitely the towbar module. I changed my looms to go from twin 7 pin sockets to the new 13 pin Jaeger socket. That's the box it plugged into.
Post #48391 1st Feb 2011 7:57pm
L7APK
Thanks fellas, i'll plug it back in and try a trailer board on it tomorrow. Thumbs Up
Post #48416 1st Feb 2011 9:47pm
