Home > Technical (L322) > Hub nut removal
Page 3 of 4 <1234>
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
or take your hubs off again... HAHA...will try to avoid that.
Thanks for all your device chicken, Yeah the bolting holes are even either side , Ill try the twist method first and let you know.
Ok here is how far I got today, after deciding which way to cut these discs , a bit daunting after spending £50 each. I cut the disc back plates right down the middle and voted to the hub and made some plates and already to weld , the bottom I should have put to the rear , all is not lost though it would balance the top and give it some support to the other side .
Post #483773 19th Jul 2018 7:08am
holidaychicken
That looks neat, once it’s tacked you can remove the supports and the bolts if it helps to move it around to weld, but better with bolts in place. I’ce done a little mig welding, I would do as a series of spots so as not to put too much heat in it to twist it. Nice brush of good seam sealer both sides and you are away. Grind an area on the plate for your earth so you keep the current local to the job and disconnect battery after following battery disconnect procedure. Apologies if I am teaching granny to suck something Very Happy
Post #483955 21st Jul 2018 7:37am
alfapat
Ha Ha a wee bit, rest assured , battery disconnected !
Hadn't thought of seam sealer , I have left bolts on and taken off to weld was marked , now painting splits with hammerite including welded brackets of course. I may spot the inner and outer ends to prevent any vibration Would seam sealer fill the small gap do you think , is there painter version.
Post #483967 21st Jul 2018 11:15am
holidaychicken
I would stitch weld it and remove the two brackets to make it look nice and neat. Paintable seam sealer similar to the link below would finish it off if you haven't welded it fully.
https://www.ebay.co.uk/itm/PU-SEALANT-PAIN...SwhiZaVH0p
Post #483988 21st Jul 2018 2:26pm
alfapat
Hmm after welding the brackets on and painting them , and all the cut marks , o everything was not to bad, I thought about stitching but it looked quite neat as it is and strong . So shoes on and new spring and pins to backing plate and discs back on .
Post #483996 21st Jul 2018 6:15pm
holidaychicken
Good job Thumbs Up
Post #484002 21st Jul 2018 7:51pm
alfapat
Hmm not a good job yet Ok , having completed the replacement of the rear abs rings on my L322 I still have a fault with the system . HDC and suspension inactive , I have below these faults yet again , it’s not that I haven’t seen them before but my only thought is that I will have to deal with the front rings , how can I conclude this theory please , should I get readings from the wiring at the abs ecu while ignition on , I may add that all four sensors have been replaced , but in the initial replacement the old ring has grazed the sensor face . Maybe measure the sensor face left ? Just a bit stuck in this long
Post #484640 29th Jul 2018 6:47pm
Mikey
What rings have you replaced?
What were the original codes?
What codes come back after you clear them?
Post #484643 29th Jul 2018 7:16pm
alfapat
The gap tool never seems to give a code , I find it sometimes quite random, The rings I have replaced are both the rears , you can see this back in the thread, The left rear appeared first then dissappeared as the speedometer indicated , but the signals were not good and as it turns out they were both gone completely. I can bring up a pic of the last three faults remaining , as per Gap tool , I will connect my other diagnostic to ascertain any faults. Thumbs Up
Post #484647 29th Jul 2018 7:42pm
alfapat
OK , the first three are the result of the last pic I downloaded, I then went into diferent diagnostic tool and got these after a run , to my surprise both rear sensors which are new albeit slightly scraped from the old rings are coming up including the can bus , which is well , not getting the right message to sync with the abs ecu.
The Gap tool remains with the original faults.
Mt question therefore having a specific tool for that model , why in hell does it not pick up yjr sensors , why would I need two diagnostics .....Arghh
Can I assume I have damaged both new sensors?
Apoligise for the upload but cant see rear left pic , it is there . I just struggle a bit with computers lol.
Post #484657 29th Jul 2018 8:58pm
Don't see an ABS fault code... Question
The LCM/EAS fault code is a daisy chain left over fault from a previous EAS fault. can clear.
The other two will just keep coming back, but according to GAP are of no real import. .
Post #484671 29th Jul 2018 11:21pm
alfapat
The Contisys Scan has picked up abs fault though?
Not easily read I admit.
I might also add that whatever the daisy chain of ecu's are saying , there must be something making this error , The Gap tool is not helpful.
The susp. is currently locked in normal ride height, but using gap tool all corners have been calibrated.
Post #484677 30th Jul 2018 6:50am
Mikey
What brand of sensors?
Post #484708 30th Jul 2018 1:20pm
alfapat
Rimmers , I think I know what your going to say though. I reckon I’ll try and temporary swap front to rears they were new also, it might prove that I damaged the rears on the old rings . I ain’t paying £100 a pop !
Post #484734 30th Jul 2018 3:22pm
Mikey
Not had anybody luck with aftermarket ones. I’ll only fit OEM/Genuine now...
Post #484761 30th Jul 2018 8:57pm
Page 3 of 4 <1234>
