Home > General > Autobiography..
Johnte
Autobiography..
Is there a way to spot a genuine one (2005), the seller says it is, but I don't think so.. If I remember correctly, don't they have a build plate attached somewhere on the body?
Post #48388 1st Feb 2011 7:43pm
daveo
should be a plate on the slam panel but i suppose you could get one if you realy wanted to, check with a dealer,give them the vin and they will tell you.. V8 facelift Range Rover Autobiography 22" wheels.
Post #48389 1st Feb 2011 7:49pm
bogie
surely the reg run through HPI check will prove date of registration etc cheers
bogie
Post #48390 1st Feb 2011 7:51pm
Johnte
I'm not sure if HPI would actually come up as 'Autobiography'?
Post #48393 1st Feb 2011 8:02pm
dan_uk_1984
& HPI can be "corrected" plus they don't guarantee trim levels.
Download Microcat, this allows you to put the reg no in and get all the build info.
Post #48396 1st Feb 2011 8:23pm
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
yes my plate is under the bonnet at the front, should be a plate saying Land rover special vehicles marked with varius info.
Post #49484 9th Feb 2011 3:43pm
