![]() | Home > General > Autobiography.. |
should be a plate on the slam panel but i suppose you could get one if you realy wanted to, check with a dealer,give them the vin and they will tell you.. V8 facelift Range Rover Autobiography 22" wheels.
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
surely the reg run through HPI check will prove date of registration etc cheers
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
I'm not sure if HPI would actually come up as 'Autobiography'? |
& HPI can be "corrected" plus they don't guarantee trim levels. Download Microcat, this allows you to put the reg no in and get all the build info. ![]() |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
yes my plate is under the bonnet at the front, should be a plate saying Land rover special vehicles marked with varius info. |
