Home > Maintenance & Mods (L322) > Heavy breath
SinbadRose
Heavy breath
Hi all. Away at the moment so no real access to internet. When revving and you take your foot off so they start to fall it sounds like a heavy breath being taken, is it normal or something else that needs looking at. Not come across it before. Can only hear it when stood outside not from in the car.
Forgot to say, no drive issue/warning lights or smoke.
Post #483976 21st Jul 2018 12:20pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
Alternator.
Just had mine done a few weeks ago. A noise appeared on mine and a week or so later the not charging message popped up! 2009 TDV8 Vogue SE - Bonatti Grey
Post #484074 22nd Jul 2018 9:23pm
SinbadRose
Thanks for that, had a quick smell around the bay and not getting anything. Will keep an eye on it.
Post #484290 25th Jul 2018 8:40am
SinbadRose
OK, had the alternator checked, and that is coming back as fine (I am told). They did say that a pipe on an air box was half off, so they sorted that at the service, couldn't hear the Darth Vadar until i got home and was doing something with the window down. Only happens when you take your foot off the accelerator, and as the revs drop Darth Vader does the breath. Before i speak to the garage, can anyone tell me where the air boxes are so i can check them myself, or any other pipe that may do a noise like that.
As i say, no warning lights, no issues when driving it, just the what sounds like a deep intake of air going through a pipe somewhere near the front.
Post #486074 14th Aug 2018 1:52pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I dont know which engine or year your car is, but lift the bonnet and look for a big black box with a ~4" plastic pipe going into it.
If it is a 4.4 TDV8 then there are two of them, one either side, just behind the headlights.
If it is a 3.6 TDV8 then I think there is only one, on the drivers side. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #486076 14th Aug 2018 2:11pm
SinbadRose
Cheers John, will check those tonight as long as the weather holds.
Post #486077 14th Aug 2018 2:19pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
On the 3.6 it's actually on the passenger side just behind the headlight. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #486084 14th Aug 2018 3:25pm
John w
Thanks, I was going from memory, only looked at a few of them Thumbs Up Too many toys, not enough time
Post #486087 14th Aug 2018 3:31pm
SinbadRose
Thanks again guys, it's the 4.4 so if the rain stops, I will have a look tonight. Anything else it could be? Will try and get a recording if i don't find anything.
Post #486097 14th Aug 2018 4:42pm
one air box each side on the 4.4, Both in the behind the headlamp sort of position. There is nothing that can't be fixed with a hammer😜😜
Post #486144 15th Aug 2018 10:42am
John w
if it sounds like a sigh, maybe it could be something disengaging, like the cooling fan ?
or maybe a servo actuator resetting itself ?
Try a few other things, like putting the car in access height, keep/take your foot on/off the brake, turn aircon and heating off, etc.
Mine clicks away to itself after turning the ignition off with various things changing position. Too many toys, not enough time
Post #486158 15th Aug 2018 12:21pm
Sinbad, this will sound abit scary but try this... Try left foot braking when stationary put the car in Reverse (make sure your not near anything behind the car) Now gun the throttle... Even better still do it up a hill! This will provoke the secondary turbo into life! You ought to hear quite some clattering/chattering from the waste gates... Report back if this sounds like the noise you are used to hearing... Thumbs Up
Post #486210 15th Aug 2018 7:24pm
SinbadRose
Yep, that sounds scary, If it turns out to be the waste gates, is it a normal noise or is this something that will need a blank cheque. Daft question but the more i learn the better. Just don't remember hearing it since i had it, but then again, don't usually stand outside the car when i did hear it.
Post #486229 15th Aug 2018 10:02pm
