![]() | Home > Maintenance & Mods (L322) > Heavy breath |
| Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148
Alternator.
| SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114
Thanks for that, had a quick smell around the bay and not getting anything. Will keep an eye on it. |
OK, had the alternator checked, and that is coming back as fine (I am told). They did say that a pipe on an air box was half off, so they sorted that at the service, couldn't hear the Darth Vadar until i got home and was doing something with the window down. Only happens when you take your foot off the accelerator, and as the revs drop Darth Vader does the breath. Before i speak to the garage, can anyone tell me where the air boxes are so i can check them myself, or any other pipe that may do a noise like that.
| John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447
I dont know which engine or year your car is, but lift the bonnet and look for a big black box with a ~4" plastic pipe going into it.
Cheers John, will check those tonight as long as the weather holds. |
| MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547
On the 3.6 it's actually on the passenger side just behind the headlight. 2016 Skoda Octavia VRS Estate
Thanks, I was going from memory, only looked at a few of them |
Thanks again guys, it's the 4.4 so if the rain stops, I will have a look tonight. Anything else it could be? Will try and get a recording if i don't find anything. |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
one air box each side on the 4.4, Both in the behind the headlamp sort of position. There is nothing that can't be fixed with a hammer😜😜
if it sounds like a sigh, maybe it could be something disengaging, like the cooling fan ?
Sinbad, this will sound abit scary but try this... Try left foot braking when stationary put the car in Reverse (make sure your not near anything behind the car) Now gun the throttle... Even better still do it up a hill! This will provoke the secondary turbo into life! You ought to hear quite some clattering/chattering from the waste gates... Report back if this sounds like the noise you are used to hearing... |
Yep, that sounds scary, If it turns out to be the waste gates, is it a normal noise or is this something that will need a blank cheque. Daft question but the more i learn the better. Just don't remember hearing it since i had it, but then again, don't usually stand outside the car when i did hear it. |
| All times are GMT |
