![]() | Home > Technical (L322) > Air Conditioning |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Pressure sounds low should be up in the 20's to 30's on the low side .
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 ![]() ![]() ![]() |
Is that 20 or 30 Bar or psi |
Sorry, psi, so 10 bar....145psi !! |
I found this piece of information but it still puts mine way off
2006Rangie Member Since: 26 Jan 2017 Location: Toronto and Melbourne Florida Posts: 22 ![]() ![]() ![]() |
The key information is the pressure on each side - low pressure and high pressure.
Looks like it might be the compressor. It goes in to the garage on Tuesday will let you know the outcome in case others get the same symptoms. |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
Is the pressure the same with engine stopped and running ?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
This is correct ![]() With the system off/inactive, both high/low pressures should read around 5bar With the system working, the high pressure can read as high as 15bar, with the low side down between 1.5-2 bar ![]() |
Turns out it is the compressor that needs replacing had a few quote. Might be winter by the time I save up lol |
Check eBay, plenty of 2nd hand ones on there. .
Finally got it replaced nice and cold ready for winter |
