Home > Technical (L322) > Air Conditioning
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Air Conditioning
I Have done some searching to no avail. My air con had a leak to which I ending up changing the pipe on the right hand inner wing.
Got my local Indy to fit for me and re-gas, but this didn't work. I was told that the gas hadn't leaked and there were no faults showing on the Auto-logic diagnostic tool but the pressure on both sides were identical at 10bar has any one else had a problem like this or can offer advice on where to look next. Any help would be gratefully received.
Post #484478 27th Jul 2018 8:11pm
Pressure sounds low should be up in the 20's to 30's on the low side .
Post #484480 27th Jul 2018 8:17pm
matlandy
Is that 20 or 30 Bar or psi
Post #484481 27th Jul 2018 8:29pm
Sorry, psi, so 10 bar....145psi !! Shocked
My STP gauge indicates that that "happy" (filled) zone is 25-40 psi... .
Post #484485 27th Jul 2018 9:11pm
matlandy
I found this piece of information but it still puts mine way off
What is the correct AC pressure?
Actual readings will vary according to ambient temperature. The low-side should be near 30 PSI at 90 degrees Fahrenheit or less. Pressure that is too much lower or higher shows there is a problem. On a properly working system, high-side pressure will be about twice the ambient temperature, plus 50 PSI.
So my low pressure should be about 30 psi and mine is way too high and my high pressure should be about 112 psi still to high. have you any idea what might cause this.
Post #484489 27th Jul 2018 9:31pm
2006Rangie
Canada 2006 Range Rover HSE 4.4 V8 Giverny Green
The key information is the pressure on each side - low pressure and high pressure.
If you compressor is working, you should get a differential pressure between the low and high sides. If your compressor is not running, you would get equal pressures on the 2 sides. If your compressor is actually running and you get equal pressures on the 2 sides, your compressor is probably dead.
At about 90 degrees F ambient, normal working pressures with a good compressor would be about 30 to 40 psi on the low side and about 230 psi on the high side.
Post #485731 11th Aug 2018 6:07pm
matlandy
Looks like it might be the compressor. It goes in to the garage on Tuesday will let you know the outcome in case others get the same symptoms.
Post #485840 12th Aug 2018 7:45pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Is the pressure the same with engine stopped and running ?
If you look at the front of the compressor and the centre is spinning (so the compressor is engaged) and the pressure is the same both sides, I would agree with you, compressor fault.
If you see the pressure increase when the engine is running, it might not be the compressor, it could be the expansion valve.
What year is your car ? Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #485864 12th Aug 2018 11:45pm
Mikey
This is correct Thumbs Up
With the system off/inactive, both high/low pressures should read around 5bar
With the system working, the high pressure can read as high as 15bar, with the low side down between 1.5-2 bar
Post #485867 13th Aug 2018 5:45am
matlandy
Turns out it is the compressor that needs replacing had a few quote. Might be winter by the time I save up lol
Post #486722 21st Aug 2018 11:26am
Check eBay, plenty of 2nd hand ones on there. .
Post #486741 21st Aug 2018 1:29pm
matlandy
Finally got it replaced nice and cold ready for winter Laughing
Post #490760 3rd Oct 2018 1:22am
John w
Laughing
Now you will need to fix the heated seats and steering wheel ready for next summer Laughing Too many toys, not enough time
Post #490795 3rd Oct 2018 12:21pm
