Home > Technical (L322) > Coolant bleeding
M17tph
England 2006 Range Rover Vogue SE Td6 Buckingham Blue
Coolant bleeding
I'm just about to do the thermostat mod on my 2002 l322 BMW petrol engine is there a method for bleeding the cooling system after refilling
Thsnks
Post #484695 30th Jul 2018 9:27am
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Here you go from Rave.
Post #484726 30th Jul 2018 1:35pm
M17tph
Excellent thank you
Post #484728 30th Jul 2018 1:39pm
holidaychicken
This might help if you get a problem , mine didn’t bleed easily when I did the mod as my auxiliary pump doesn’t work. I burp the rubber hoses to expel air and raise the front of the vehicle.
This is good info
http://www.meeknet.co.uk/E38/E38_Bleeding_The_Cooling_System.htm
Post #484781 30th Jul 2018 11:00pm
Warning as they can be a real pig to bleed sir Rolling Eyes
Post #484783 30th Jul 2018 11:26pm
holidaychicken
Indeed, there are few threads around the net of people with the M62 engine thinking they have head gasket failure which turns out to be bleeding issues.
i fill the header almost to the brim and keep squeezing the lower and upper rad pipes with the engine running , avoiding chopping your fingers off on the fan of course
Post #484785 31st Jul 2018 6:27am
kanikune
Finland 2004 Range Rover Vogue 4.4 V8 Epsom Green
When I did the thermostat swap, I followed the RAVE but I poured coolant in really slowly.
It went straight in. Afterwards I could only add really small amount.
I would guess pouring coolant with haste can form air pocket into the system.
Post #484798 31st Jul 2018 9:32am
M17tph
Mod done with 740d 88c thermostat bled as per rave instructions been for a drive in sport mod with air con flat out no problems so far fingers crossed
Post #485247 5th Aug 2018 6:02pm
holidaychicken
I think the 88 deg stat bleeds easier, i never had any problems bleeding until I fitted the 80 deg mod.
Post #485273 5th Aug 2018 10:23pm
