Home > Technical (L322) > Eas abs reset tool |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
Mine has twice lost sync with itself ie wouldn't start and had to roll back the CCM - might not have been the only solution but it worked and both times in foreign lands so 11d tool more than paid for itself |
14th Aug 2018 8:23am |
Tried the battery disconnect it seemed the key had lost sync with the immobiliser but rolling back the ccm worked did this after speaking to the boys at GAP who were brilliant great support when in a foreign land |
14th Aug 2018 4:17pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Mabe a new key? |
15th Aug 2018 8:40am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Did you check the for sale section for 2nd user iiDTools ? .
15th Aug 2018 10:45am |
Yes could not find anything suitable have just received carsoft and will get it up and running shortly a lot cheaper than is .£136 free delivery |
15th Aug 2018 11:18am |
Should read iid predictive text again |
15th Aug 2018 11:19am |
Ok so air suspension pipe repaired and reset with carsoft no prob easy to use .Saving money already 👍 |
15th Aug 2018 4:04pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Good fix Rik Current: 2011 FFRR Vogue SE 4.4 TDV8
15th Aug 2018 4:43pm |
15th Aug 2018 10:13pm |
Oh and I wrapped some rubber underlay around pipe so it don't happen again |
15th Aug 2018 10:17pm |
