![]() | Home > Technical (L322) > Eas abs reset tool |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Mine has twice lost sync with itself ie wouldn't start and had to roll back the CCM - might not have been the only solution but it worked and both times in foreign lands so 11d tool more than paid for itself |
Tried the battery disconnect it seemed the key had lost sync with the immobiliser but rolling back the ccm worked did this after speaking to the boys at GAP who were brilliant great support when in a foreign land |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
Mabe a new key? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Did you check the for sale section for 2nd user iiDTools ? |
Yes could not find anything suitable have just received carsoft and will get it up and running shortly a lot cheaper than is .£136 free delivery |
Should read iid predictive text again |
Ok so air suspension pipe repaired and reset with carsoft no prob easy to use .Saving money already 👍 |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Good fix Rik |
Oh and I wrapped some rubber underlay around pipe so it don't happen again |
