Home > Technical (L322) > Just about to put up for sale
Waynetab
United Kingdom 2004 Range Rover HSE 4.4 V8 Galway Green
when it all starts to go wrong.
Don't know if its relevent but accidentally left my headlamps on for a few hours last Thursday.
Presently battery reading with engine off 12.5v, running 14.1v.
Car started and ran fine next day but on Saturday I got a bong and air suspension inactive-HDC inactive-ABS light-brake lights-HDC and low range lit up.
Using my iid tool I get the following that I can clear but instantly return.
0x57 Air suspension active/inactive
0x68 Steering angle sensor ecu internal fault (new one fitted 3 years ago this month)
0x5A Temporary system deactivation
0x32 Can bus fault
0xBD EBV function fault from ABS ecu
Searched on previous threads and other than steering angle sensor say that standard fault no action or old code??
Have also noticed voltage showing on dash 13.6v. Never seen this displayed before?
Battery on charge now and fingers crossed. (Bosch 020 S5015 Silver 2 years old)
How does she know I am about to sell?? Not Galway but Balmoral green actually
148,000 miles
Post #486732 21st Aug 2018 11:34am
Voltage on dash usually shows when you have the iiDTool plugged in ?
Your codes point to an issue with either the air suspension or the steering angle sensor.
Suggest you check air suspension all round for height sensor issues, or leaky bag / pipe. .
Post #486740 21st Aug 2018 12:27pm
Waynetab
Voltage, yes I have been forgetting to take out the iid tool.
Will check for leaks, thanks Not Galway but Balmoral green actually
148,000 miles
Post #486745 21st Aug 2018 12:35pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I think that leaving the IID Tool connected can drain power which could lead to all manner of “faults” being displayed. Just a thought. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #486750 21st Aug 2018 1:12pm
Waynetab
Recalibrated steering angle sensor and all seems fine. Would leaving the lights on have affected the steering angle sensor?? coincidence?
Is it because she knows I am looking to sell?. No trouble at all so far this year, there again shouldn't be seeing as I have spent over 5k last few years.
Will leave a week or so before I put it up for sale though. Not Galway but Balmoral green actually
148,000 miles
Post #486755 21st Aug 2018 1:22pm
Waynetab
"I think that leaving the IID Tool connected can drain power which could lead to all manner of “faults” being displayed. Just a thought."
Just made me realise I have left it plugged in again doh! Not Galway but Balmoral green actually
148,000 miles
Post #486760 21st Aug 2018 1:49pm
Paul thornton
I think I've seen you're car knocking around the bury area.
I presumed it was wrapped / repainted at first until I learned recently that it's the original colour.
Post #486768 21st Aug 2018 3:55pm
Waynetab
Spoke too soon, not solved the problem.
After calibrating the steering wheel sensor I raised it, lowered it. Turned it off, back on, raised and lowered again. No problem.
Later jumped in it to go home and BONG all back again with all the same faults plus a new one
0x87 tachometer
Guess it must be the steering angle sensor?? Not Galway but Balmoral green actually
148,000 miles
Post #486769 21st Aug 2018 4:10pm
verydisco
I can confirm one should not leave it on as it will indeed drain the battery a bit. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #486770 21st Aug 2018 4:10pm
Waynetab
Hi Paul,
I do get to Bury on a Saturday a few times a month.
Not original colour, was resprayed by Overfinch at 7 weeks old. Original owner didn't want to wait 12 months to get that colour from Range rover I believe?? Not Galway but Balmoral green actually
148,000 miles
Post #486771 21st Aug 2018 4:12pm
