![]() | Home > Technical (L322) > Just about to put up for sale |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Voltage on dash usually shows when you have the iiDTool plugged in ?
| Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132
Voltage, yes I have been forgetting to take out the iid tool.
| Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240
I think that leaving the IID Tool connected can drain power which could lead to all manner of “faults” being displayed. Just a thought. 2006MY 4.2 SC
Recalibrated steering angle sensor and all seems fine. Would leaving the lights on have affected the steering angle sensor?? coincidence?
"I think that leaving the IID Tool connected can drain power which could lead to all manner of “faults” being displayed. Just a thought."
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545
I think I've seen you're car knocking around the bury area.
Spoke too soon, not solved the problem.
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
I can confirm one should not leave it on as it will indeed drain the battery a bit. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
Hi Paul,
| All times are GMT |
