![]() | Home > Technical (L322) > Heavy steering |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Apart from checking the TPs which I presume you've already done , worn tyres can cause heavy steering after that fluid level in the reservoir , after that fluid condition ,
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Faulty BCM (body control module) - situated under passenger seat - can cause heavy steering. Do u have one or two doors with intermittent locking/unlocking problems? Then this needs changing |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
I have one door with intermittent unlocking issue |
Can this just be cleared using tool are does it require replacement? |
Don’t think it can be cleared, it needs replacing. It’s an easy enough 1/2 hr-1hr job (write up on wiki http://www.fullfatrr.com/forum/topic40009.html
Thanks |
