Home > Technical (L322) > New noise in park, neutral only plus one more question!!
Darryl72
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hiya folks just another day in the life of a l322 owner, as the title mine has developed a spinning/ metallic type noise not often but only in park or neutral,drives and pulls like it should.
My thoughts are possibly oil not getting circulated properly but it's just an uneducated shot in the dark .
I have tried reset through the hidden menu and also battery disconnect/ touching as I have another issue, I turn the key through 1 and as it gets to position two the car starts not allowing the glow plugs to heat normally , so it's not getting as far as postition 3 against the spring, starts every time but of course it's not right.??
Are these issues related?
Thanks in advanced people.
Update.....
Whilst ideling on my drive my RR has died, quite a large pop sounds and then whispers of smoke, now turning the key lights up the dash, deploys the steering column but does not start the car,just a single click sound.
Post #487834 2nd Sep 2018 2:10pm
Darryl72
Just another thought..is it possible a dodgy starter motor would effect the ignition sequence? Likely the starter motor has died....sorry I'm lost so any assistance would be great.
Post #487900 3rd Sep 2018 6:45pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Where was the smoke from ?? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487901 3rd Sep 2018 6:58pm
Darryl72
I'm not sure it was coming up when lifted the bonnet.around the rear of the block is all I can narrow it down. Possibly starter motor....is that possible?
Post #487904 3rd Sep 2018 8:21pm
dolph34
Im far from an expert but smoke could be a burnt cable more thannthe starter motor. Hopefully one of the experts on here will chime in shortly. Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487905 3rd Sep 2018 8:32pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
What voltage is the battery reading? 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #487910 3rd Sep 2018 8:50pm
Darryl72
Don't know I can check tomorrow afternoon, what are you thinking Mike?
Post #487913 3rd Sep 2018 8:59pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
It sounds to me like your starter motor has possibly got stuck engaged, and has burnt itself out, or the contacts on the solenoid.
Do a web search and you should find some pictures of the engine out of the car to give you a clue where to check.
This should get you started (no pun intended Wink )
https://workshop-manuals.com/landrover/l32..._motor_td6 Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #487919 3rd Sep 2018 9:43pm
MikeO
I was wondering if it could be your alternator. They have a habit on Discos of burning out and taking the battery with them when they go.
https://disco3.co.uk/forum/post1943171.html#1943171 2016 Skoda Octavia VRS Estate
Post #487921 3rd Sep 2018 9:51pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Ignition switch gone faulty causing starter to be engaged maybe ? New switch and starter needed maybe ?
Post #487926 3rd Sep 2018 11:18pm
steptoe
A year and model of car would be helpful.
Post #487981 4th Sep 2018 2:14pm
Darryl72
Right thanks everyone I have something to work with, at the weekend my first thing will be to remove and test the starter motor (just wishing my arms were another two foot longer...looks a pig)
There is a good write up on here by mercs600 if anyone else needs it
http://www.fullfatrr.com/forum/post62119.html
Steptoe my car details are under my name just hover over the icon,
Mike my battery is reading 11.6 a little low, would that rule out alternator?
Any other thoughts please add them, thanks again, I am trying not to have go through the garage, transporting money pit route just yet.
Post #487993 4th Sep 2018 5:15pm
MikeO
Cheap and easy to charge the battery - should really be over 12V, ideally 12.3V+ with engine off and car asleep. See if charging it makes any difference.
With engine running it should be higher if the alternator is okay - typically around 14V I think. You'll find some detailed figures on here if you search for battery / alternator. 2016 Skoda Octavia VRS Estate
Post #488025 4th Sep 2018 9:46pm
Darryl72
Thanks again folks,I reckon my starter motor has gone!!!
Post #488367 8th Sep 2018 8:27am
Darryl72
@ Kds2 looks about right on the switch also.
The electronic parts look like they can be cleaned and saved in the picture but the plastic spindle is scrap, anyone know if it can be bought seperate?
Post #488419 8th Sep 2018 6:44pm
