![]() | Home > Technical (L322) > New noise in park, neutral only plus one more question!! |
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 ![]() ![]() ![]() |
Just another thought..is it possible a dodgy starter motor would effect the ignition sequence? Likely the starter motor has died....sorry I'm lost so any assistance would be great. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Where was the smoke from ?? 2015 4.4 AB
I'm not sure it was coming up when lifted the bonnet.around the rear of the block is all I can narrow it down. Possibly starter motor....is that possible? |
Im far from an expert but smoke could be a burnt cable more thannthe starter motor. Hopefully one of the experts on here will chime in shortly. |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 547 ![]() ![]() ![]() |
What voltage is the battery reading? 2016 Skoda Octavia VRS Estate
Don't know I can check tomorrow afternoon, what are you thinking Mike? |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 447 ![]() ![]() ![]() |
It sounds to me like your starter motor has possibly got stuck engaged, and has burnt itself out, or the contacts on the solenoid.
I was wondering if it could be your alternator. They have a habit on Discos of burning out and taking the battery with them when they go.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 226 ![]() ![]() ![]() |
Ignition switch gone faulty causing starter to be engaged maybe ? New switch and starter needed maybe ? |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
A year and model of car would be helpful. |
Right thanks everyone I have something to work with, at the weekend my first thing will be to remove and test the starter motor (just wishing my arms were another two foot longer...looks a pig)
Cheap and easy to charge the battery - should really be over 12V, ideally 12.3V+ with engine off and car asleep. See if charging it makes any difference.
